Updates for EZLogic - 1.30.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com
Previous: 1.29.1
Cloud MeshBot. Cloud Variables as Triggers
We provided ability to use Cloud Variables as a Trigger in Cloud MeshBot.
But first, let’s create a variable.
Note: Steps, how to create a variable described in 1.24.1
I want a variable, which will represent the number of spreadsheets on my account and I want to update the value everyday. The MeshBot could have the following structure:
Note: Variable will be created after MeshBot execution.
I want to be notified when the number of spreadsheets exceeds 100. Let’s create another MeshBot.
  1. Select Cloud Variable node.
  2. Select Service from the list.
    Note: we display here only the services that already have variables.
  3. Choose an account:
  4. Select a variable:
  5. Select comparator:
  6. Provide a value to compare with:
The full trigger row:
And the MeshBot could look like:
When the number of spreadsheets will exceed 100, the user will get email and notification.
Fixes and Improvements:
  1. Sorted countries alphabetically, removed duplicates, put United States and Canada to the top of the list.
  2. Fixed highlighting for the accounts in Trigger section using the same token value.
Thanks!
With 1.30.1 I’m not able to select Users in the notification action:
Hi @Odysee ,
This issue didn’t replicate on our end, could you please refresh with a cache bypass or erase the cache and try again?
Are using a Local Automation Meshbot?
I’ve already disabled the cache in Chrome Browser but clearing the browser data did solve the problem.
I hope this general problem that occurs again and again regarding the cache will finally be solved. It is very annoying that you have to manually delete the browser data after each new version.
