Updates for EZLogic - 1.10.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com
Previous 1.9.1
Updates:
Plugins. Wi-Fi Device Generator
Plugin release notes.
Have a look on 1 min video how to install the plugin, create the template and WiFi device.
https://www.youtube.com/watch?v=La6Q_bVV_js
The UI for plugin placed on Plugins → WiFi Device Generator page. But before, you have to install it from Marketplace.
Steps:
Go to Plugins → Edge Plugins → Marketplace, find the Ezlo WiFi device generator plugin and press Copy to my ezlo button.
Go to My Private Plugins then press Manage installations button, select the online controller to install.
You are ready to go!
Open Plugins → WiFi Device Generator page
Here you can see the same structure as on Edge Plugins page. You have listing of private device templates, your published templates and marketplace.
To create your template click + Create New Configuration button, fill the fields and press Save Model template.
Current plugin version supports switch and dimmer capabilities.
- To generate device click Create device button, fill the fields and click create device button.
Congratulations! We generated the device. Now, it is possible to use it as ordinary device in EZLogic.
- You can manage device setup on Device Settings page.
Cloud MeshBot. Actions. NuCAL
Even if you don’t have a controller, you still can create a Cloud MeshBot and use NuCAL services as an Action.
We provided ability to make test API call and see the response in preview area.
Fill the fields and press Test button. Response could be represented as an Object or in Raw formats.
Fixes and Improvements
- Fixed validation for trigger functions.
- Fixed UI for functions.
- Fixed payload for NuCAL Test API call in Local MeshBot.
Thanks!
