Updates for EZLogic - 1.9.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com
Previous 1.8.1
Updates:
Local MeshBot. Action. NuCAL node. Test button
It is possible to make a test call and see the output of the command.
Fill the required fields press the TEST button.
The output could be represented as an Object
and in Raw formats.
Fixes and Improvements
  • Added validation for Latch block name.
    Block name field is required.
  • Prevent MeshBot form clearing when switching between controllers. You will not lose your progress untill you press Continue button.
  • Overall minor UI improvements, including Local MeshBot True/False Action tabs header
Thanks!
As of this update, I can’t seem to save changes to meshbots, or create new ones. The Save button remains disabled at all times.
Hi, @ibrewster
Validation for functions fixed under 1.9.3 version
