They are still working on it apparently. Some of their Devs also use Imperihome and they are aware of the problem I’ve been told this morning.
Thanks you
I have the same problem with ImperiHome remotely,
considering that VeraMobile lacks a sensible interface and any programming logic, I found a temporary solution, with a RaspberryPi and OpenHabian3 installed, using the MiOS binding as a bridge that immediately detected the Scenes and Devices of my VeraEdge.
Now I play with all possible interfaces and, I must say, the Vera controller responds more quickly.
Not sure if you guys have seen this: Imperihome is no more . It seems Imperihome is getting out of business.
Hi
yes that I know, for a long time, but that does not explain why on the side Vera it does not work any more. ok imperihome is stopped, for their part, no more updates, no server or services. But the application does not need it to continue working with Vera Plus.
Looks like Imperihome app was using an older host for our cloud endpoints, which had a redirect in place to our current hosts. The machine running the proxy had some malfunctioning hardware which is going to be replaced next week.
hope this is the soulution. I discover that Imperihome is running on an Android 6 device well, but not on a 10 anymore
Hi
what do you mean ? Mine worked on Android 9 and 10
What did you do that you Android 10 device is working again?
I have an old LG Cell with Android 6. Imperi is working on it
Hi
I installed the lite version 4.3.17 and the pro version 2.0.1
there is a login problem with imperihome servers (which no longer exists) that I got around by importing my last backup and then using the widget shortened to the dashboard
Imperihome is working again after re-install. Don’t know why - but happened on 2 devices.
Hi
I had the same problem on my samsung s10, forced to reinstall it to work locally …
Hi Pitt13,
where did you store your last back up and how did you restore? I purchased the 4.x version where registration is needed and backup and restore is via imperihome cloud. I have as well old 3.x apks where an account is not needed but on backup possible. There is no way by the App to restore the json file.
The way you descibed with the widget does not work if no dashboard exists.
Hi
my backup is stored locally, you have to go to Setting, General Parameter, then Export. Yes necessarily to use the shortcut to the Dashboard there must be a Dashboard created
Imperihome create the backup but before it asks for a password, it creates a zip file in which the json is located. Everything is as before it actually pays off.
Ok lets assume to install the lite version 4.3.17 and the pro version 2.0.1 on a new device. The widget “dashboard” call a board which does’t exists and stops. How to overcome/proceed.
Hi
are you using pages or the listview?
if it’s the listview it doesn’t work
you have to create a page, either the dashboard or another page, the widget will call this one
Understood, but when it is a new install - you don’t have pages yet. You have to link the vera the first time
Hi
I haven’t tried it but I think with a version of the app that doesn’t ask for a login it should work
You can launch Imperihome via its regular icon on Android if its a version of Imperihome that has no login functionality present.
