And the one in the Google Play store which I just installed is version 1.114.0.561
So the App stores have the new versions I mentioned in that other thread.
I canât seem to find where to use the fence. I created one, but I canât see anywhere in the meshbot option to use it as a trigger.
10 posts were split to a new topic: Issues with Thermostat tiles in new âNative Dashboardâ in Mios iOS app
Press More button then âGeofencingâ.
How do you use the geofence as a trigger? I donât see it listed in the meshbot creator
Bill
Im not sure I havent looked at the Geo fence stuff yet.
However the Mios app release notes suggest it may be possible.
It might be that the firmware on the controller and the âAdvanced Scenesâ also needs updating to catch up?
Iâll ask someone.
Meshbots in the web UI has to be updated yet to support it. Dont have an ETA for that yet. So we have to wait a while.
Was told the following.
iOS MiOS app - does have Geofencing. In the app User can setup location and register the device(iPhone). This device will send current location to be used in meshbot triggers
Current Web UI Ezlogic live version 2.4.3- doesnât have geofencing support. Need to release it.
What will be released:
User can create Cloud Meshbot based on geofence location and the registered device.
User can browse Geofencing Settings: location and the registered device. Can enable/disable geofencing.
Geofencing is not supported in Local meshbots.
The current Android MiOS app - doesnât have Geofencing currently.
Hello,
Ezlogic has been updated and now includes Geofence capability integration into the Cloud MeshBots.
We look forward to your comments.
I tested and it didnât seem to work
How does this interact with the House Modes?
And why are Vera and Ezlo interacting with each other? For Example in the Vera App thereâs now an option as to which fence list you want to use Vera or Ezlo.
Iâve noticed this with notifications as well. These are two separate systems why are they interconnected?
Jonathan did you try and test the Geo fencing yet? Did it work for you?
I will try it later myself.
Is House Modes even working properly on the Ezlo platform ?
It wasnât last time I looked at it and there was a whole thread about it here.
How is it this device is considered a production status unit, it seems more like itâs still beta.
Wasnât the controller âreleasedâ almost 4 years ago? Basic functionalities still donât work. I still canât get local weather like I can on my Vera. And canât delete the non functioning Ezlo weather cloud services entries.
At this point I canât see trying to migrate any of my devices over, especially if house modes does not work.
I have the same problem. I asked that team for an update on when the Cloud Services will be fixed again? Apparently they had to re-write them all for some reason. Why they just didnât temporarily remove that âCloud Servicesâ area from the web UI and block it, until they fixed it all again I am not sure.
I am pushing them for House Modes to be fixed and also completed to be in feature parity with how it works on the Vera hubs / system. I am asking them to make it a high priority.
They were finalizing the rewrite at the end of March.
Hello @cw-kid
Not yet. I will try later today.
Any results?
Hello @Tim88
Unfortunately, it didnât work, but I noticed that my iPhone settings were set to âWhile Using the App.â Iâll try again later today with the setting changed to âAlways.â
How can you tell if itâs working or not unless you are setting a virtual switch or something similar,unless itâs working with the home modes?
How does it handle multiple users?
