You can also see the support page with the up to date list here.
Hi All,
As you know, we have been building our own Z-Wave stack from ground up. We had two things in mind, performance and stability!
We are now ready to share the progress on supported Z-Wave classes and integrated devices as of today.
We will be updating this post after each release.
You can see the %age coverage of all Z-Wave command classes in visual format and how we make progress for each release “S” above means “Sprint” which is a development cycle.
You can see how we make progress for each release on the number of Z-Wave devices. “S” above means “Sprint” which is a development cycle. TAM consist from the number of devices that we put as the total addressable market for now. RtOS FW is the FW currently running on Atom and Plughub. Linux FW is our brand new linux based FW that is being used on Ezlo Plus for now.
Supported Command Classes:
| # | Command Classes | Hex | Dec |
| 1 | Notification Access Control | 0x71 | 113 |
| 2 | Notification - CO Alarm | 0x71 | 113 |
| 3 | Notification - Home Security | 0x71 | 113 |
| 4 | Notification - Smoke Alarm | 0x71 | 113 |
| 5 | Notification - Water Alarm | 0x71 | 113 |
| 6 | CO2 Alarm | 0x71 | 113 |
| 7 | Heat Alarm | 0x71 | 113 |
| 8 | Power Management | 0x71 | 113 |
| 9 | System | 0x71 | 113 |
| 10 | Emergency Alarm | 0x71 | 113 |
| 11 | Clock | 0x71 | 113 |
| 12 | Appliance | 0x71 | 113 |
| 13 | Home Health | 0x71 | 113 |
| 14 | Siren | 0x71 | 113 |
| 15 | Water Valve | 0x71 | 113 |
| 16 | Weather Alarm | 0x71 | 113 |
| 17 | Irrigation | 0x71 | 113 |
| 18 | Gas alarm | 0x71 | 113 |
| 19 | Pest Control | 0x71 | 113 |
| 20 | Light sensor | 0x71 | 113 |
| 21 | Water Quality Monitoring | 0x71 | 113 |
| 22 | Home monitoring | 0x71 | 113 |
| 23 | BASIC | 0x20 | 32 |
| 24 | ALARM | 0x71 | 113 |
| 25 | SCENE_ACTIVATION | 0x2B | 43 |
| 26 | CONFIGURATION | 0x70 | 112 |
| 27 | ASSOCIATION | 0x85 | 133 |
| 28 | ASSOCIATION_GRP_INFO | 0x59 | 89 |
| 29 | MULTI_CHANNEL_ASSOCIATION | 0x8E | 142 |
| 30 | FIRMWARE_UPDATE_MD | 0x7A | 122 |
| 31 | ZWAVEPLUS_INFO_ | 0x5E | 94 |
| 32 | BATTERY | 0x80 | 128 |
| 33 | DEVICE_RESET_LOCALLY | 0x5A | 90 |
| 34 | MANUFACTURER_SPECIFIC | 0x72 | 114 |
| 35 | VERSION | 0x86 | 134 |
| 36 | MULTI_CHANNEL | 0x60 | 96 |
| 37 | SECURITY_0 | 0x98 | 152 |
| 38 | SECURITY_2 | 0x9F | 159 |
| 39 | SUPERVISION | 0x6C | 108 |
| 40 | TRANSPORT SERVICE | 0x55 | 85 |
| 41 | NO_OPERATION | 0x00 | 0 |
| 42 | POWERLEVEL | 0x73 | 115 |
| 43 | SWITCH_BINARY | 0x25 | 37 |
| 44 | METER | 0x32 | 50 |
| 45 | COLOR_SWITCH | 0x33 | 51 |
| 46 | SWITCH_MULTILEVEL | 0x26 | 38 |
| 47 | CENTRAL_SCENE | 0x5B | 91 |
| 48 | THERMOSTAT_FAN_MODE | 0x44 | 68 |
| 49 | THERMOSTAT_FAN_STATE | 0x45 | 69 |
| 50 | THERMOSTAT_MODE | 0x40 | 64 |
| 51 | THERMOSTAT_OPERATING_STATE | 0x42 | 66 |
| 52 | THERMOSTAT_SETBACK | 0x47 | 71 |
| 53 | THERMOSTAT_SETPOINT | 0x43 | 67 |
| 54 | CLOCK ? | 0x81 | 129 |
| 55 | HRV_STATUS | 0x37 | 55 |
| 56 | HRV_CONTROL | 0x39 | 57 |
| 57 | Air temperature | 0x31 | 49 |
| 58 | Illuminance | 0x31 | 49 |
| 59 | Power | 0x31 | 49 |
| 60 | Humidity | 0x31 | 49 |
| 61 | Velocity | 0x31 | 49 |
| 62 | Direction | 0x31 | 49 |
| 63 | Atmospheric pressure | 0x31 | 49 |
| 64 | Barometric pressure | 0x31 | 49 |
| 65 | Solar radiation | 0x31 | 49 |
| 66 | Dew point | 0x31 | 49 |
| 67 | Rain rate | 0x31 | 49 |
| 68 | Tide level | 0x31 | 49 |
| 69 | Weight | 0x31 | 49 |
| 70 | Voltage | 0x31 | 49 |
| 71 | Current | 0x31 | 49 |
| 72 | Carbon dioxide CO2-level | 0x31 | 49 |
| 73 | Air flow | 0x31 | 49 |
| 74 | Tank capacity | 0x31 | 49 |
| 75 | Distance | 0x31 | 49 |
| 76 | Rotation | 0x31 | 49 |
| 77 | Water temperature | 0x31 | 49 |
| 78 | Soil temperature | 0x31 | 49 |
| 79 | Seismic Intensity | 0x31 | 49 |
| 80 | Seismic magnitude | 0x31 | 49 |
| 81 | Ultraviolet | 0x31 | 49 |
| 82 | Electrical resistivity | 0x31 | 49 |
| 83 | Electrical conductivity | 0x31 | 49 |
| 84 | Loudness | 0x31 | 49 |
| 85 | Frequency | 0x31 | 49 |
| 86 | Time | 0x31 | 49 |
| 87 | Target temperature | 0x31 | 49 |
| 88 | Particulate Matter 2.5 | 0x31 | 49 |
| 89 | Formaldehyde CH2O-level | 0x31 | 49 |
| 90 | Radon concentration | 0x31 | 49 |
| 91 | Methane (CH4) density | 0x31 | 49 |
| 92 | Volatile Organic Compound level | 0x31 | 49 |
| 93 | Carbon monoxide (CO) level | 0x31 | 49 |
| 94 | Soil humidity | 0x31 | 49 |
| 95 | Soil reactivity | 0x31 | 49 |
| 96 | Soil salinity | 0x31 | 49 |
| 97 | Heart rate | 0x31 | 49 |
| 98 | Blood pressure | 0x31 | 49 |
| 99 | Muscle mass | 0x31 | 49 |
| 100 | Fat mass | 0x31 | 49 |
| 101 | Bone mass | 0x31 | 49 |
| 102 | Total body water (TBW) | 0x31 | 49 |
| 103 | Basis metabolic rate (BMR) | 0x31 | 49 |
| 104 | Body Mass Index (BMI) | 0x31 | 49 |
| 105 | Acceleration X-axis | 0x31 | 49 |
| 106 | Acceleration Y-axis | 0x31 | 49 |
| 107 | Acceleration Z-axis | 0x31 | 49 |
| 108 | Smoke density | 0x31 | 49 |
| 109 | Water flow | 0x31 | 49 |
| 110 | Water pressure | 0x31 | 49 |
| 111 | RF signal strength | 0x31 | 49 |
| 112 | Particulate Matter 10 | 0x31 | 49 |
| 113 | Respiratory rate | 0x31 | 49 |
| 114 | Relative Modulation level | 0x31 | 49 |
| 115 | Boiler water temperature | 0x31 | 49 |
| 116 | Domestic Hot Water (DHW) temperature | 0x31 | 49 |
| 117 | Outside temperature | 0x31 | 49 |
| 118 | Exhaust temperature | 0x31 | 49 |
| 119 | Water Chlorine level | 0x31 | 49 |
| 120 | Water acidity | 0x31 | 49 |
| 121 | Water Oxidation reduction potential | 0x31 | 49 |
| 122 | Heart Rate LF/HF ratio | 0x31 | 49 |
| 123 | SILENCE_ALARM | 0x9D | 157 |
| 124 | BARRIER_OPERATOR | 0x66 | 102 |
| 125 | DOOR_LOCK | 0x62 | 98 |
| 126 | Clock | 0x71 | 113 |
| 127 | SOUND_SWITCH | 0x79 | 121 |
Integrated Devices:
| # | Manufacturer | Model Number | Device Type |
| 1 | Zooz | ZSE40 | |
| 2 | ASPIRE RF Wireless by Eaton Wiring | RFLDM | |
| 3 | Evolve Guest Controls | LDM-15 | |
| 4 | Aeotec | DSC27103-ZWUS | |
| 5 | Leviton Manufacturing, Inc. | DZ6HD | |
| 6 | Zooz | ZEN27 | |
| 7 | Aeotec | ZWA002-A | |
| 8 | Aeotec | ZWA001-A | |
| 9 | Hank | HKZW-RGB01 | |
| 10 | Leviton Manufacturing, Inc. | DZ1KD | |
| 11 | Zipato | rgbwe27zw | |
| 12 | SATCO | 86-103 | |
| 13 | Jasco Products Company | ZW3106/28175 | |
| 14 | Vizia RF+ | VRE06_0810 | |
| 15 | Intermatic Inc | HA05 | |
| 16 | Aeotec | ZW110 | |
| 17 | GE | 14292/ZW4003 | |
| 18 | Jasco | 14318/ZW4005 | |
| 19 | Jasco | 14321/ZW3005 | |
| 20 | Jasco | 14319/ZW4003 | |
| 21 | ASPIRE RF Wireless by Eaton Wiring | RF9536 | |
| 22 | ASPIRE RF Wireless by Eaton Wiring | RF9534 | |
| 23 | Dome | DMOF1 | |
| 24 | Aeotec | ZW078-A | |
| 25 | Zipato | rgbw2 us | |
| 26 | ZLINK | WS-100 | |
| 27 | GE | 45604 | |
| 28 | Leviton Manufacturing, Inc. | DZ15S | |
| 29 | Leviton | DZPA1 | |
| 30 | Philio | PAN15 | |
| 31 | GoControl | WO15Z-1 | |
| 32 | GoControl | WS15Z5-1 | |
| 33 | SATCO | 86-100 | |
| 34 | EATON | RF9501 | |
| 35 | Remotec | ZFM-80 | |
| 36 | EATON | RFAPM | |
| 37 | EATON | RF9518 | |
| 38 | EATON | RFTR9505-T | |
| 39 | EATON | RF9640-NDW | |
| 40 | EATON | RFTR9605-T | |
| 41 | Honeywell | 39354/ZW4003 | |
| 42 | Honeywell | 39349/ZW1002 | |
| 43 | Enerwave | ZW15SM-PLUS-W | |
| 44 | Enerwave | ZW15RM-PLUS | |
| 45 | Enerwave | ZWN-RSM2-PLUS | |
| 46 | Enerwave | ZW500DM-PLUS | |
| 47 | GE | 14289/ZW3009 | |
| 48 | GE | 14288/ZW1002 | |
| 49 | Honeywell | 39358/ZW4002 | |
| 50 | Honeywell | 39351/ZW3005 | |
| 51 | GoControl | LB60Z-1 | |
| 52 | GoControl | WD500Z-1 | |
| 53 | Ge/Jasco | 45602WB | |
| 54 | Decora Z-Wave Controls | DZPD3 | |
| 55 | GoControl | LBR30Z-1 | |
| 56 | HomeSeer | HS-WD200+ | |
| 57 | GE/Jasco (Enbrighten) | 39723 | |
| 58 | Jasco Products Company | 14280 (ZW3107) | |
| 59 | Oomi | FT121-A | |
| 60 | ASPIRE RF Wireless by Eaton Wiring | RF9537-N | |
| 61 | FIBARO | FGD-212 | |
| 62 | ZLINK | WD-100 | |
| 63 | GE | 14287 / ZW4002 | |
| 64 | Schlage | BE469NX | |
| 65 | GoControl | PD300EMZ5-1 | |
| 66 | Aeotec | ZW096-B09 | |
| 67 | FIBARO | FGWPB-111 | |
| 68 | Vizia RF+ | VRF01 | |
| 69 | HomeSeer | HS-FC200+ | |
| 70 | Jasco Products Company | 14287 | |
| 71 | Intermatic | PE953 | |
| 72 | Aeotec | DSD37-ZWUS | |
| 73 | GE | ZW3006 | |
| 74 | GE | 28167/ZW3104 | |
| 75 | ZLINK | PD-100 | |
| 76 | Honeywell | 39336/ZW3104 | |
| 77 | Honeywell | 39339/ZW3107 | |
| 78 | GoControl | WD500Z5-1 | |
| 79 | Danalock | Danalock V3-BTZU | |
| 80 | Yale Locks & Hardware | YRD216-ZW2 | |
| 81 | Alfred | DB2 | |
| 82 | Schlage | BE469ZP | |
| 83 | Kwikset | 888 | |
| 84 | Kwikset | 916 | |
| 85 | Philia | PDS-100 | |
| 86 | Yale Locks & Hardware | NTB620-ZW2 | |
| 87 | Yale | YRD256-ZW2 | |
| 88 | Aeotec | ZW117-G17 | |
| 89 | Ring | 4AR1S70EN0 | |
| 90 | Philio | PST02-C | |
| 91 | Philio | PST02-B | |
| 92 | Ecolink Intelligent Technology | DWZWAVE2.5-ECO | |
| 93 | Ecolink Intelligent Technology | PIRZWAVE2.5-ECO | |
| 94 | GE/Jasco | 32562/32563 | |
| 95 | Neo Coolcam | NAS-DS01Z | |
| 96 | Philio | PSM08 | |
| 97 | Neo Coolcam | NAS-PD01Z | |
| 98 | Philio | PAT02-2B | |
| 99 | Philio | PST02-A | |
| 100 | GoControl | WO15EMZ5-1 | |
| 101 | Zooz | ZEN15 | |
| 102 | Neo Coolcam | NAS-WR01Z | |
| 103 | ZLINK | PA-100 | |
| 104 | Honeywell | 39342/ZW4106 | |
| 105 | Honeywell | 39346/ZW4201 | |
| 106 | Honeywell | 39337/ZW4103 | |
| 107 | Evolve Guest Controls | LOM-15 | |
| 108 | Evolve Guest Controls | LPM-15 | |
| 109 | Vizia RF+ | VRR15_0806 | |
| 110 | SATCO | 86-102 | |
| 111 | HomeSeer | HS-WS200+ | |
| 112 | GE | 28169/ZW4103 | |
| 113 | GE | ZW4106 | |
| 114 | Intermatic | CA3500 | |
| 115 | HomeSeer | HS-FLS100+ | |
| 116 | FIBARO | FGS-223 | |
| 117 | GoControl | PS15EMZ5-1 | |
| 118 | Ecolink Intelligent Technology | DDLS2-ZWAVE5 | |
| 119 | Ecolink Intelligent Technology | SDLS2-ZWAVE5 | |
| 120 | Aeotec | ZW189 | |
| 121 | SWF | VCZ1 | |
| 122 | SWF | BRZ1 | |
| 123 | SWF | MCZ1 | |
| 124 | Everspring | SE812 | |
| 125 | FortrezZ LLC | SSA1 - SSA2 01 | |
| 126 | Dome | DMS01 | |
| 127 | Dome | DMWD1 | |
| 128 | Philio | PSP05 | |
| 129 | FIBARO | FGK10x | |
| 130 | Zooz | ZSE29 | |
| 131 | Aeotec | ZW112-A | |
| 132 | Aeotec | ZW120-A | |
| 133 | Aeotec | ZW089-A | |
| 134 | FIBARO | FGMS-001 | |
| 135 | Vision | ZP3102-5 | |
| 136 | Everspring | SM810 | |
| 137 | Vision | ZP3111-5 | |
| 138 | Vision | ZD2102-5 | |
| 139 | FIBARO | FGDW-002 | |
| 140 | Everspring | HSM02-0 | |
| 141 | GE | 34193/ZW6302 | |
| 142 | Dome | DMMS1 | |
| 143 | HomeSeer | HS-FS100+ | |
| 144 | Everspring | SF813 | |
| 145 | HomeSeer | HS-DS100+ | |
| 146 | Intermatic Inc | CA9000 | |
| 147 | HomeSeer | HS-MS100+ | |
| 148 | Nexia | TH100NX | |
| 149 | Aeotec | ZW187 | |
| 150 | Jasco | 43973/ZW6305 | |
| 151 | Philio | PSE02 | |
| 152 | Neo Coolcam | NAS-AB01Z | |
| 153 | GE | 12727/ZW4003 | |
| 154 | Philio | PAN06 | |
| 155 | GE | 12729 / ZW3004 | |
| 156 | Honeywell | YTH8320ZW1007 | |
| 157 | GoControl | TBZ48 | |
| 158 | Remotec | ZTS-500 | |
| 159 | Radio Thermostat Company of America | CT100 | |
| 160 | SWF | CSZ1 | |
| 161 | SWF | RSZ1 | |
| 162 | Philio | PAN08-1 | |
| 163 | Somfy | 1870171 RevA | |
| 164 | GE | 14284/ ZW4201 | |
| 165 | ECOLINK | TILT-ZWAVE2.5-ECO | |
| 166 | Yale | YRD246ZW20BP | |
| 167 | GE / Jasco | 14294 | |
| 168 | GE / Jasco | 14291 | |
| 169 | Yale | YRD240-ZW-0BP | |
| 170 | Zooz | ZEN06 VER. 2.0 | |
| 171 | Zooz | ZEN22 VER. 3.0 | |
| 172 | Zooz | ZEN24 VER. 3.0 | |
| 173 | Zooz | ZSE18 | |
| 174 | Aeotec | ZW121 | |
| 175 | Aeotec | ZWA005 | |
| 176 | GE | 14295/ZW3004 | |
| 177 | Jasco Products Company | 14322/ZW3004 | |
| 178 | Jasco Products Company | 45762/ZW3004 | |
| 179 | Jasco Products Company | 45742/ZW3004 | |
| 180 | FIBARO | FGS-213 | |
| 181 | FIBARO | FGWPE/F-101 | |
| 182 | Sensative AB | MaZw | |
| 183 | Kwikset | 914C | |
| 184 | Eaton | RF9601 | |
| 185 | Sunricher | SR-ZV9040A-B | |
| 186 | LEEDARSON | 6A-PL-VAB-A0 | |
| 187 | Hank | HKZW-SW02 | |
| 188 | Sercomm | SW-ESW01N | |
| 189 | Hank | HKZW-SO03 | |
| 190 | Hank | HKZW-SO01 | |
| 191 | Enerwave | ZWN-333M | |
| 192 | GE/Jasco | ZW3011 | |
| 193 | GE/Jasco | ZW4009 | |
| 194 | GE/Jasco | ZW4008DV | |
| 195 | GE/Jasco | ZW3010 | |
| 196 | Ecolink Intelligent Technology | STLS2-ZWAVE5 | |
| 197 | Ecolink Intelligent Technology | DTLS2-ZWAVE5 | |
| 198 | Inovelli | LZW31 | |
| 199 | Remotec | ZDS-200NA | |
| 200 | Remotec | ZRP-100NA | |
| 201 | Ezlo | B-2700-6W-A19-US | |
| 202 | Neo Coolcam | NAS-WS01Z | |
| 203 | Dome | DMWS1 | |
| 204 | Jasco | ZW4009 | |
| 205 | Neo Coolcam | NAS-MS01Z | |
| 206 | Everspring | SP816-2 | |
| 207 | Inovelli | LZW30 | |
| 208 | Aeotec | ZW080 | |
| 209 | GE | 14285/ZW4007 | |
| 210 | Everspring | SE813 S2 | |
| 211 | Aeotec | ZWA008 | |
| 212 | Everspring | ST812 | |
| 213 | Philio | PAT02-A | |
| 214 | Philio | PAT02-2C | |
| 215 | Fortrezz | WWA-01AA | |
| 216 | Fibaro | FGFS-101 GEN5 | |
| 217 | Fortrezz | FTS05 | |
| 218 | Fibaro | FGDW-002 | |
| 219 | Ecolink | FLF-ZWAVE5 | |
| 220 | Ring | 4SF1S80EN0 | |
| 221 | Aeotec | ZW141 | |
| 222 | Neo Coolcam | NAS-SC03ZE-2 | |
| 223 | Fibaro * | FGWOE-011 | |
| 224 | Fibaro * | FGWOF-011 | |
| 225 | GE/Jasco | 34172/ZW5304 | |
| 226 | GE/Jasco | 34174/ZW5305 | |
| 227 | GE/Jasco | 34176/ZW5306 | |
| 228 | GE/Jasco | 28177/ZW4105 | |
| 229 | Dome | DMMZ1 | |
| 230 | Fibaro | FGWPF-102 | |
| 231 | First Alert | ZCOMBO | |
| 232 | Vision | ZS6301-5 | |
| 233 | Fibaro | FGCD-001 | |
| 234 | Hank | HKZW-SO09 | Smart Plug |
| 235 | Remotec | ZDS-110NA | Plug-in Dimmer |
| 236 | GE/Jasco | 26931/ZW4006 | In-Wall Smart Motion Switch |
| 237 | Fibaro* | FGWDEU-111 | Wall Dimmer |
| 238 | MCO Home | MH-P220 | Micro Dimmer |
| 239 | Ecolink | FF-ZWAVE5-ECO | Smoke and CO Audio Detector |
| 240 | Fibaro | FGD-212 | Dimmer 2 |
| 241 | Neo Coolcam | NAS-WS02Z | Water Sensor |
| 242 | GE/Jasco | 26933/ZW3008 | In-Wall Smart Motion Dimmer |
| 243 | Philio | PAU05 | Range Extender Repeater |
| 244 | GLinear | GD00Z-5 | Garage Door Controller |
| 245 | GoControl | GD00Z-4 | Garage Door Controller |
| 246 | Nutone | NGD00Z | Garage Door Controller |
| 247 | Aeotec | ZWA003-A | NanoMote Quad |
| 248 | Fibaro | FGPB-101 | Button |
| 249 | Nortek | GD00Z-8 | Garage Door Opener |
| 250 | Everspring | HSP02 | Motion Sensor |
| 251 | Aeotec | DSA03202W-ZWEU | Minimote |
| 252 | GoControl | WA00Z-1 | Smart Switch Cover |
| 253 | Fibaro | FGWPB-121 | Wall Plug |
| 254 | Philio | PSG04 | CO Sensor |
| 255 | Philio | PSR07 | Smart Color Button |
| 256 | Aeotec | DSA38 | Panic Button |
| 257 | GE/Jasco | 37792/ZW5307 | 2 Button Hub/Panel Remote |
| 258 | Inovelli | LZW30-SN | On/Off Switch (Red Series) |
| 259 | Neo Coolcam | NAS-RP01Z | Repeater |
| 260 | Sensative | 1102012/2 | Strips Drip |
| 261 | Leviton | RZP15-1LW | Plug-In Appliance Module |
| 262 | Leviton | VRP03_0806 | Scene Capable Plug-in Dimmer Module |
| 263 | Inovelli | LZW31-SN | Dimmer Switch |
| 264 | Heiman | HS1DS-Z | Door Window Sensor |
| 265 | Heiman | HS1HT-Z | Temperature Sensor |
| 266 | Schlage | DWZWAVE1 | Door/Window Sensor |
| 267 | Fibaro | FGKF-601 | Keyfob |
| 268 | Fibaro | FGS-213 | Single Switch 2 |
| 269 | Zooz | ZEN20 | Power Strip |
| 270 | Zooz | ZEN21 | On/Off Light Switch |
| 271 | Zooz | ZEN23 | On/Off Toggle Switch |
| 272 | Zooz | ZEN25 S2 | Double Plug |
| 273 | Zooz | ZEN26 S2 | On Off Switch |
| 274 | Heiman | HS2SK-Z | Smart Plug |
| 275 | Heiman | HS1MS-Z | Motion Sensor |
| 276 | Heiman | HS1WL-Z | Water Leak Sensor |
| 277 | Heiman | HS1SA-Z | Smoke Sensor |
| 278 | Heiman | HS2WD-Z | Siren |
| 279 | MCO Home | MH-DT511 | Touch PaneI Dimmer |
| 280 | Heiman | HS1CA-Z | Carbon Monoxide Sensor |
| 281 | Philio | PAD11 | Smart Dimmer Plug |
| 282 | Sensative | 1102012/1 | Strips Comfort |
| 283 | GoControl | WT00Z5-1 | Accessory Dimmer |
| 284 | Aeotec | ZW130-A | WallMote Quad |
| 285 | Aeotec | ZW129-A | Wallmote Dual |
| 286 | Remotec | ZRC-90 | Scene Controller |
| 287 | Nexia | NX1000 | One Touch |
| 288 | Nodon | CRC-3-1 Octan | Powerful Remote Scene Controller |
| 289 | Nodon | CRC-3-6-xx | Soft Remote |
| 290 | Philio | PSR04 | Smart Color Button |
| 291 | Hank | HKZW-SCN01 | Scene Controller |
| 292 | Hank | HKZW-SCN04 | Scene Controller |
| 293 | Popp | POPE700892 | Door/Window Sensor |
| 294 | Popp | POPP004001 | Smoke Sensor/Siren |
| 295 | Qubino* | ZMNHYDx | Smart Plug 16A |
| 296 | Qubino | ZMNHSDx | DIN Dimmer |
| 297 | Qubino | ZMNHHDx | Mini Dimmer |
| 298 | Fibaro | FGSD-002 | Smoke Sensor |
| 299 | TKB Home | TZ66-D | On/Off Module |
| 300 | Leedarson | 6A-PL-VAB-A0 | Smart Plug |
| 301 | Aeotec | ZW111 | Nano Dimmer |
| 302 | Dome | DMDP1 | Door/Window Sensor Pro |
| 303 | Hank | HKZW-MS01 | Multisensor |
| 304 | Domitech | ZE27EU/ZB22UK/dtA19-750-27 | Smart LED Light Bulb |
| 305 | Ecolink | ECO-DW | Door/Window Sensor |
| 306 | Philio | PSM02 | MultiSensor |
| 307 | Aeotec | ZWA019-A | Water Sensor 7 Pro |
| 308 | Philio | PAN11 | Smart Energy Plug-In Switch |
| 309 | Nortek | WADWAZ-1 | Door/Window Sensor |
| 310 | Nortek | WAPIRZ5-1 | Wireless PIR Motion Sensor |
| 311 | Vision | ZM1601-5 | Vision Wireless Siren & Strobe |
| 312 | Nortek | WA105DBZ-1 | Siren and Strobe |
| 313 | Aeotec | DSB05 | MultiSensor |
| 314 | Aeotec | DSC06106 | Smart Energy Switch |
| 315 | Everspring | AN186-1 | On/Off Plug |
| 316 | Jasco | ZW4202 | Plug-In Outdoor Smart Switch |
| 317 | Inovelli | LZW40 | Smart Bulb |
| 318 | Zooz | ZSE19 S2 | Multisiren |
| 319 | Vision | ZF5201-5 | Flood Detector |
| 320 | Sercomm | SW-DWS02N | Door/Window Sensor |
| 321 | Philio | PSG01 | Smoke Sensor |
| 322 | Ei Electronics | EIA207RFZ | Z-Wave Smart Carbon Monoxide Alarm |
| 323 | Philio | PAN16 | Plug-In Switch |
| 324 | Sercomm | SW-PIR03N | Motion Sensor |
| 325 | Philio | PSP01 | 3-in-1 MultiSensor |
| 326 | Aeotec | DSC24 | Smart Switch |
| 327 | Aeotec | DSC25 | Smart Dimmer |
| 328 | Vision | ZD2105-5 | Recessed Door / Window Sensor |
| 329 | Nortek/GoControl | WD1000Z-1 | Z-Wave In Wall Dimmer, 1000W |
| 330 | Nortek/Linear | PD300Z-2 | Dimmer Module |
| 331 | Philio | PAD02 | Smart Dimmer Socket |
| 332 | Nortek/GoControl | PS15Z-2 | Appliance Module |
| 333 | Vision | ZR1202-5 | Z-Wave Repeater |
| 334 | Aeotec | DSC18103 | Micro Smart Switch (2E) |
| 335 | GE/Jasco | ZW4008 | |
| 336 | Aeotec | DSB29 | Door/Window Sensor |
| 337 | Aeotec | DSB54 | Recessed Door Sensor |
| 338 | Neo Coolcam | NAS-SC01ZE | 2-Channel Wall Switch |
| 339 | Neo Coolcam | NAS-SC02ZU-2 | Light Switch |
| 340 | Ecolink | SC-ZWAVE5 | Wireless Siren |
| 341 | Honeywell | 39342/ZW4106 | Plug-in Smart Switch |
| 342 | Vision | ZP3113-7 | 4 in 1 PIR Sensor |
| 343 | Vision | ZG8101 | Garage Door Detector |
| 344 | Philio | PAN05-1B | In wall Single relay (1 way) switch module |
| 345 | Philio | PAN03-1B | Switch module with meter |
| 346 | Philio | PAN10-1B | Switch module with meter |
| 347 | Aeotec | DSB04100 | Door/Window Sensor |
| 348 | Schlage | PIRZWave1 | PIR Sensor |
| 349 | Hawking | HRDS1 | Door/Window Sensor |
| 350 | MCO Home | MH-S212 | Mini Combo Switch |
| 351 | Sensative | 11 01 022/1 | Strips Guard 700 |
| 352 | Sensative | 11 04 022/1 | Strips Drip 700 |
| 353 | Intermatic | HA06 | Wall Dimmer |
| 354 | Evolve | LRM-1000 | Lightning Dimmer |
| 355 | Fibaro | FGSS-001 | Smoke Sensor |
| 356 | Chromagic | HSP02 | Motion Detector |
| 357 | Vision | 4BH2-10002 | Water Leak Sensor |
| 358 | Vision | ZW4111-5 | Curtain Control Module |
| 359 | GE/Jasco | 14311/ZW4201 | Outdoor Smart Switch |
| 360 | GE/Jasco | ZW3101/1243 | Lamp Module |
| 361 | Hank | HKZW-DWS01 | Door/Window Sensor |
| 362 | Utilitech | #0422362/TST01-1 | Water Leak Detector |
| 363 | Utilitech | #0422360/TSE07-1 | Wireless Indoor Siren |
| 364 | GE/Jasco | 28172/ZW4104 | Plug-in Smart Switch |
| 365 | Honeywell | 39348/ZW4005/ZW4008 | In-Wall Smart Switch |
| 366 | Eaton | RF96APM | ON/OFF Plug-In Module |
| 367 | Horus | HSC-ZD2102US-5 | Door Sensor |
| 368 | Horus | HSC-ZP3102US-5 | Motion Sensor |
| 369 | Evolve | LSM-15 | Wall Switch |
| 370 | MCO | Home MH-D220 | Micro Dimmer |
| 371 | Wintop | iDoorContact | D/W Sensor |
| 372 | Horus | HSC-S511-B | Energy Switch |
| 373 | Vision | ZT1101-5 | 4 Button Keyfob |
| 374 | Horus | HSC-P511-B | Energy Dimmer |
| 375 | Aeotec | ZW175-C16 | Smart Switch 7 |
| 376 | Heatit | 45 126 86 Z- | Repeater |
| 377 | Jasko | ZW4105 | Smart Switch |
| 378 | Jasko | ZW4002 | In-wall smart Fan Control |
| 379 | Jasko | ZW3107 | Plug-inSmart Dimmer |
| 380 | Eaton | RF9601D | Z-Wave Wireless Switch |
| 381 | Leviton | R03-DZPD3-1BW | Plug-in Lamp Dimmer Module |
| 382 | Zooz | ZEN26 VER.3.0 | S2 on/off switch 3.0 |
| 383 | Enerwave | ZW15SM-PLUS | WIRELESS HOME AUTOMATION SMART DEVICE |
| 384 | Aeotec | ZW080-A17 | Siren Gen5 |
| 385 | Leviton | VRPD3-1LW | Scene capable plug-in module |
| 386 | Zooz | ZEN24 ver3.0 | Toggle dimmer |
| 387 | Honeywell | ZW3104 | Plug-in smart dimmer |
| 388 | Fibaro | FGFS-101 ZW5 v3.4 | Flood Sensor |
| 389 | Aeotec | ZW187-A | Recessed Door Sensor 7 |
| 390 | Aeotec | ZW110-A02 | Smart Switch 6 |
| 391 | Aeotec | ZWA001 | LED Bulb Gen6 Multi-White |
| 392 | Fibaro | FGDW-002-1 | Door/Window sensor 2 |
| 393 | Kwikset | 914 | SmartCode |
| 394 | Zooz | ZSE29 VER 2.0 | outdoor motion sensor |
| 395 | Enbrighten GE | ZW3106 | Plug-in Smart Dimmer |
| 396 | Dome | DMDP2 | Wireless Z-Wave Door/Window Sensor |
| 397 | Enbrighten GE | ZW3008 | Smart Motion Dimmer |
| 398 | Aeotec | ZWA008-A | Door/Window sensor 7 |
| 399 | Enbrighten GE | ZW3009 | In-wall Touch Sensing Smart Dimmer |
| 400 | Fibaro | FGD-212 us v3.5 | Dimmer 2 |
| 401 | Zooz | ZEN27 ver3.0 | S2 on/off switch |
| 402 | Sensative | 1101012 | Strips Guard |
| 403 | Jasko | ZW6302 | Smart Motion sensor |
| 404 | Ecolink | DW-ZWAVE2.5-ECO | Door/Window sensor |
| 405 | Enbrighten GE | ZW4006 | Smart Motion Switch |
| 406 | Yale | B076WZT4VD | yale assure lock sl with z-wave manual |
| 407 | Aeotec | ZWA005-A | TriSensor |
| 408 | Leviton | HSP02-0 | Motion Sensor |
| 409 | Enbrighten GE | ZW3005 | In-wall smart dimmer |
| 410 | Fortrezz | 8156a-fm5202 | Flood Sensor |
| 411 | Enbrighten GE | 46202/ZW4009 | In-Wall Smart Switch |
| 412 | Zooz | ZEN23 VER. 4.0 | Togle switch |
| 413 | Enbrighten GE | 14294 / ZW3005 | In-Wall smart dimmer |
| 414 | Aeotec | ZW117-A01 | Range Extender 6 |
| 415 | Enbrighten GE | ZW4201/39346 | Plug-in Outdoor Switch |
| 416 | Enbrighten GE | 14315/14288/ZW1002 | In-Wall Tamper Resistant Smart Outlet |
| 417 | Enbrighten GE | ZW4003/14292 | In-Wall Smart Toggle Switch |
| 418 | Enbrighten GE | ZW6301/32563 | Hinge Pin Door Sensor |
| 419 | Leviton | VRR15-1LZ | White/Ivory/Light Almond |
| 420 | Zooz | ZEN22 VER. 4.0 | Dimmer 4.0 |
| 421 | Honeywell | ZW4103/39337 | Plug-in Switch (Single Plug) |
| 422 | Zooz | ZEN15 ver2.0 | Power Switch |
| 423 | Enbrighten GE | ZW3006/14299 | In-Wall Smart 1000W Dimmer |
| 424 | Fibaro | FGGC-001 | SWIPE |
| 425 | Kwikset | 910 | Smartcode |
| 426 | Sensative | KIT 11 01 011/1101 | Strips Guard |
| 427 | Minoston | MP21Z | Z-Wave Outlet Mini Plug-in Socket |
| 428 | NodOn | CRC-3US-1 | Z-Wave Plus Octan Powerful Remote Scene Controller |
| 429 | GoControl | WAPIRZ-1 | Z-Wave PIR Motion Detector |
| 430 | Philia | PAN11-4 | SMART ENERGY PLUG-IN SWITCH Z-WAVE SERIES/WATT METER REPORT 2 IN 1 |
| 431 | Ecolink | SC-ZWAVE5-ECO | Zwave Plus Network Security Siren, White |
| 432 | Zooz | ZSE19 | Zooz Z-Wave Plus S2 MultiSiren ZSE19 with Temperature and Humidity Sensors |
| 433 | Enbrighten GE | GE 45603 | GE 45603 Z-Wave Technology Wireless Lighting Control Fluorescent Light & Appliance Module |
| 434 | Minoston | MP22Z | Outdoor On/Off Outlet Switch |
| 435 | Leviton | VRE06-1LZ | Leviton VRE06-1LZ Vizia RF + 600W Electronic Low Voltage Scene Capable Dimmer, White/Ivory/Light Almond, Works with Alexa |
| 436 | Sensative | Strips Comfort | Sensative Z-Wave Plus Indoor/Outdoor Temperature and Light Sensor Strips Comfort, Works with SmartThings |
| 437 | Aeotec | ZW189-A01 | Aeotec Range Extender 7 Zwave Repeater Work with Zwave Hub SmartThings Fibaro |
| 438 | Aeotec | DSA38-ZWUS | Aeotec Panic Button, Z-Wave One Button Remote Control, Scene Trigger |
| 439 | Fibaro | FGBHDW-002-1 v. 1.0 | Door/Window Sensor Contact & Temperature Sensor |
| 440 | heatit | 4512686 | Z-Repeater Range Extender Dual USB 2A |
| 441 | Ring | 1523 | Range Extender for Ring Alarm |
| 442 | Honeywell | ZW3005 | In-wall smart dimmer |
| 443 | Kwikset | 914 | SmartCode Touchpad Electronic Deadbolt featuring SmartKey Security and Avalon Handleset |
| 444 | Fibaro | FGS-223 us v3.3 | Double switch 2 |
| 445 | Yale | YRD256-ZW2-619 | yale assure lock sl with z-wave manual |
| 446 | UltraPro | 39351 | In-Wall Dimmer |
| 447 | Jasco | 45742-1 | Dimmer Switch |
| 448 | Philia | PSE02-2B | Siren |
| 449 | Fortrezz | FTS05us | Flood and Temperature Sensor |
| 450 | Yale | YRD110-ZW-619 | Lock Keypad Deadbolt in Satin Nickel |
| 451 | Somfy | ZRTSI RTS 16 | Channel Z-Wave to RTS Plug-in Interface Wall Module |
| 452 | Enerwave | ZWN-BPC-PLUS | Z-Wave Plus Ceiling Sensor ZWN-BPC-PLUS, White |
| 453 | Neo | NAS-AB02ZU-G | Z-Wave Plus Siren Alarm with Strobe alerts |
| 454 | RGBgenie | ZV-1008 | RGBW LED Driver Dimmer and Repeater,Constant Voltage Strip Light Controller with built-in Power Supply. |
| 455 | Delaney | GR-105N | Smart Home Automation Z-Wave Gas/Water Auto Shutoff Valve for Pipes up to 1 1/2 Compatiable Smartthings Vera |
| 456 | RGBgenie | ZW-4001 | Micro Controller and Lamp Module - Single Channel Trailing Edge Dimmer with Momentary Switch Input |
| 457 | UltraPro | 39354 | Z-Wave Plus Smart Light Switch, in-Wall Toggle |
| 458 | Ring | 4SF1S8-0EN0 | Ring Alarm Flood and Freeze Sensor |
| 459 | Fortrezz | ZC08-16040002 | Wireless Z-Wave Multi-Input/Output Dry Contact Bridge MIMOLite |
| 460 | Aeotec | ZW095 | Aeotec by Aeon Labs ZW095 ZW095-A Home Energy Meter Gen5, Small, White |
| 461 | Enerwave | ZWN-RSM1-PLUS | Hidden Smart Switch Wireless Remote Control to Lights and Ceiling Fans |
| 462 | Fortrezz | MIMO2US | FortrezZ Z-WavePlus MiMO2+ Interface Module |
| 463 | Aeotec | ZW111-A | Aeotec Nano Dimmer lighting controlle |
| 464 | Aeotec | ZW141-A | Aeotec Nano Shutter, Z-Wave Plus Controller Automatic Blinds Curtains, Shades, Gates, Smart Blinds Invisible Installation |
| 465 | Leviton | ZW15R-1BW | Decora Smart Tamper-Resistant Outlet |
| 466 | Enbrighten GE | ZW4203 | Smart Outdoor Switch, 1-Outlet Plug-In (2nd Gen.) |
| 467 | Honeywell | Z5OUTLET | Tamper Resistant Smart Outlet |
| 468 | Aeotec | ZW164-A | Indoor Siren 6 |
| 469 | Enbrighten GE | ZW2003 | In-Wall Add-On Switch |
| 470 | Enbrighten GE | AS2005 | In-Wall Add-On Switch |
| 471 | NEO Coolcam | NAS-PD02ZU | Motion Sensor Detector Home Automation |
| 472 | Aeotec | ZW158-Z | Wall Swipe |
| 473 | Aeotec | ZW139-A | Nano Switch |
| 474 | Eaton | RF9640-N | Universal Smart Dimmer |
| 475 | Ring | Range Extender | Alarm Range Extender |
| 476 | Ring | Panic Button | Alarm Panic Button |
| 477 | Qubino | ZMNHWD3 | Z-Wave Plus RGBW Controller ZMNHWD3 for 12-24V LED Strips and Light Bulbs |
| 478 | Schlage | BE469ZP V CAM 619 | Smart deadbolt |
| 479 | Kwikset | 912 | Smart Code touchpad electronic deadbolt |
| 480 | Aeotec | ZW132-A | Dual Nano Switch |
| 481 | Trane | ZSENS930AW00MA | Temp/Hum Sensor |
| 482 | Eaton | RF9617DW | Wireless Switch |
| 483 | STELPRO | STZW402+ | Electronic termostat |
| 484 | GoControl | LB65R6Z-1 | Smart Retrofit Lightning Kit with LED Bulb |
| 485 | Zooz | Zen31 | RGBW dimmer |
| 486 | Neo | 39122200 | Z-Wave Plus Smart Light Switch 1 Gang 2 Switchs in-Wall Smart Switch Touch Panel Touch Sensitive |
| 487 | Zipato | PH-PAN03.US | Micromodul Single Switch |
| 488 | heatit | 45 126 82 | Z-Push Button 4 |
| 489 | heatit | 45 125 81 | Z-Push Button 8 |
| 490 | Honeywell | TH8320ZW | Z-WAVE Enabled 7-DAY Programmable Thermostat with Wire saver |
| 491 | GoControl | GC-TBZ48 | Z-Wave Battery-Powered Smart Thermostat |
| 492 | TRANE | TZEMT524AA21MA | 14942771 Thermostat, Z-Wave, Works with Alexa |
| 493 | Enbrighten GE | ZW4007/ZW4004 | 40-Amp Indoor/Outdoor Metal Box Smart Switch |
| 494 | Fibaro | FGBS-222 | Smart Implant |
| 495 | Sensative | RC10 | Drips 700 US |
| 496 | heatit | 45 125 61 | Z-Din 616 |
| 497 | Sensative | RC10 | Guard 700 Us |
| 498 | heatit | 45 124 75 | Z-Water |
| 499 | Aeotec | ZW-07A | Heavy Duty Smart Switch Gen5 |
| 500 | Evalogik | ZW31S | In-Wall Smart Dimmer Switch |
| 501 | Haozee | B0923ZFHB2 | Door/Window sensor with temperature and humidity |
| 502 | Evalogik | ZW39 | Smart Plug |
| 503 | Enbrighten GE | 28166/ZW3104 | Smart Dimmer |
| 504 | Fibaro | FGMS-001 ZW5 v3.3 | Motion Sensor |
| 505 | Enbrighten GE | 52247/ZW6309 | Flood/Freeze Sensor |
| 506 | Zooz | ZEN34 | Remote Switch |
| 507 | Enbrighten GE | 53831/ZW5314 | Hub/Panel Remote |
| 508 | Aeotec | ZWA023-A | Smart Switch 7 |
| 509 | Evalogik | ZW96 | Smart Plug Outdoor |
| 510 | Yale | YRD156-ZW2-619 | Locks & Hardware |
| 511 | Enbrighten GE | 52251/ZW6307 | Smart Motion Sensor |
| 512 | Enbrighten GE | 46562 | In-Wall Smart Switch |
| 513 | Enbrighten GE | 53829/ZW5313 | Hub/Panel Remote |
| 514 | Minoston | MS11ZS | Smart Dimmer Switch |
| 515 | Yale | AYR202-ZWV-USA | Smart Module |
| 516 | Heltun | HE-FT01 | Fan Coil Thermostat |
| 517 | Schlage | FE599NX Cam 716 ACC | Connected Keypad Lever |
| 518 | Heltun | HE-HT01 | Heat Thermostat |
| 519 | Yale | B-YRD226-ZW-CM-0BP | Assure Touchscreen with Cambridge Knob-Works with Ring Alarm |
| 520 | Heltun | HE-TPS05 | Advanced Programmable Z-Wave Touch Panel Switch |
| 521 | 2GIG | CT-30 | Radio Thermostat |
| 522 | Yale | YRD216-ZW3-619 | Locks & Hardware 700 |
| 523 | Yale | YRD216-ZW2-619 | Push Button Deadbolt |
| 524 | HomeSeer | HS-LS100+ | Leak Sensor |
| 525 | EcoNetControls | EVC200-HCSML | Valve Robot |
| 526 | Neo | NAS-WR02 | Power Plug |
| 527 | NEO Coolcam | - | Light Switch 3 Buttons |
| 528 | NEO Coolcam | - | Light Switch 2 Buttons |
| 529 | Zooz | ZEN32 | Scene Controller |
| 530 | Schlage | BE469ZPV CAM 716 | Smart Deadbolt with alarm |
| 531 | Kwikset | 99160-021 | Smart Code 916 Touchscreen Deadbolt Door Lock |
| 532 | Kwikset | 99100-065 | Motor-driven deadbolt latch |
| 533 | iBlinds | IB3.0-ZWU | motor smart |
| 534 | WaterCop | ZWACT | Electric Actuator Motor |
| 535 | Dome | DMWV1 | Water Main Shut-off |
| 536 | NEO Coolcam | NAS-RP01 | Repeater |
| 537 | Honeywell | RCHT8600ZW | T5 Touchscreen Programmable Thermostat |
| 538 | Kwikset | 99160-017 | |
| 539 | Qubino | ZMNHHD3 | Mini Dimmer |
| 540 | Qubino | ZMNHOD3 | Flush Shutter DC |
| 541 | Qubino | ZMNHVD3 | Flush Dimmer |
| 542 | Qubino | ZMNKID3 | Flush On/Off Thermostat 2 |
| 543 | Qubino | ZMNHTD1 | Smart Meter |
| 544 | Heiman | HS1SA-Z | Smoke Sensor |
| 545 | Aeotec | ZWA012-A | Door/Window Sensor 7 Pro |
| 546 | Leviton | VRP15-1LW | Vizia RF Plus Plug-In Dimmer |
| 547 | Aeon | 4-in-1 sensor | |
| 548 | Honeywell | TH6320ZW2003 | T6 Pro Series Z-Wave Stat Thermostat |
| 549 | Fibaro | FGRGBW-442 | FIBARO RGBW Controller 2 Z-Wave Plus LED Strips Regulator |
| 550 | Kwikset | 99540-001 | Obsidian Touchscreen Electronic Deadbolt ZW500 |
| 551 | Kwikset | 99140-019 | SmartCode914 Touchpad Electronic Deadbolt |
| 552 | illumino | ZWA038-A | Wall Switch |
| 553 | illumino | ZWA037-A | Dimmer Switch |
| 554 | MCO HOME | MH-S512 | Touch panel switch |
| 555 | Zooz | ZEN77 | S2 Dimmer 700 series |
| 556 | Kwikset | 99140-133 | SmartCode Touchpad Electronic Deadbolt |
| 557 | Enbrighten GE | ZW4103 | Smart Switch |
| 558 | Leviton | ZW4SF | 4-Speed Fan Controller |
| 559 | Ecolink | PN - DDLS2-ZWAVE5 | Dual Rocker Style Light Switch |
| 560 | POPP | POPE700397 | Smart Outdoor Plug |
| 561 | POPP | POPE701479 | Flow Stop2 |
| 562 | Amazon | Power Plug | |
| 563 | Schlage | BE469ZP V CAM716 | Smart Deadbolt with alarm |
| 564 | Kwikset | 99140-103 | Lock with Home Connect |
| 565 | Yale | YRD226-ZW3-619 | Locks & Hardware 700 |
| 566 | MCO HOME | A8-9 | Multi Sensor Temperature Sensor, Humidity, PM2.5, CO2, COV, PIR, Lighting, Noise, Smoke |
| 567 | Zooz | ZEN17 | |
| 568 | Fibaro | FGWOE-011 | |
| 569 | Minoston | MS10ZS | |
| 570 | Minoston | MS12ZS | |
| 571 | Aeotec | FBA_DSB29xxx-ZWUS | |
| 572 | Enbrighten GE | ZW4008DV | |
| 573 | keyWe | GKW-2000D | |
| 574 | Inovelli | LZW42 | |
| 575 | GoControl | WO15EMZ5-1 | |
| 576 | Enerwave | ZWN-333 | |
| 577 | EUROTRONIC | - | |
| 578 | NEO Coolcam | PIR Motion Sensor | |
| 579 | RGBgenie | ZW-1002 | RGBW LED Controller |
| 580 | Zooz | ZSE41 | open/close xs sensor |
| 581 | Fibaro | FGWOF-011 | Walli Type F Intelligent Socket |
| 582 | Eaton | RF9640-ND | Universal Smart Dimmer |
| 583 | UltraPro | 54890 | In-Wall Smart Switch |
| 584 | Telguard | GDC1 | Garage Door Control Switch |
| 585 | Remotec | ZXT-600 | AC Master |
| 586 | Aeotec | ZWA037-A | Illumino Dimmer Switch |
| 587 | KAIPULE | IX30 | Wall-Mounted PIR Motion Sensor |
| 588 | Inovelli | LZW31-SN | Dimmer Switch |
| 589 | Qolsys | ZW080-A17 | IQ Siren |
| 590 | Safe Grow | NSG-AB-02 | Outlet Plug |
| 591 | The Remote | PSR03 | Remote |
| 592 | Aeotec | ZW120-A | Door/Window Sensor Gen5 |
| 593 | KAIPULE | IX30-ZWAVE-USA | PIR Motion Sensor |
| 594 | Utilitech | TSE07-1 | Wireless Indoor Siren |
| 595 | Baldwin | 8235.190.ZW | Touchscreen Boulder Deadbolt |
| 596 | Baldwin | 8235.150.ZW | Touchscreen Boulder Deadbolt |
| 597 | newone | N4001 | Mini Smart Plug |
| 598 | Satco | 86-100 | Plug-In Appliance Module |
| 599 | Honeywell | zw4203 | Z-Wave Plug-In Outdoor Smart Switch |
| 600 | Leviton | VRPA1-1LW | Scene Capable Plug-In Module |
| 601 | Aeotec | ZWA037-A | Dimmer Switch |
| 602 | Dome | DMWV1 | Ware Valve Shut-Off |
| 603 | KAIPULE | IX32-ZWAVE-USA | Ceiling-Mounted PIR Motion Sensor |
| 604 | Danalock | V3-BTZU | Lock V3 |
| 605 | Fortrezz | SSA1 | Siren Stobe Alarm Wireless |
| 606 | 2GIG | 2GIG-GC3-345 | Security and Automation System |
| 607 | HomeSeer | HS-WX300 | In-Wall Dimmer & Switch |
| 608 | Fibaro | FGWREU-111 | Walli Roller Shutter |
* Devices with a star (*) next to their name are supported for EU Version only
You can see also the support page with the up to date list here.
