Anyone using TriSensor 8 (ZWA045) with Ezlo hub?
This device is listed on the “Supported” devices page
https://community.ezlo.com/t/ezlo-platform-z-wave-supported-command-classes-devices/212644
Once the device has been paired to the controller, the Z-Wave Device Parameter settings can be set in Ezlogic web UI in the Settings - Devices area on the device itself.
If you need any help from the Support team @JonathanB can assist you.
