Found an oddity.
For some testing, I added a Danalock v3 to the Ezlo Plus (or, at least I tried). You go to pair it and it recommends encryptioon+verification (of course). However, when it switches to the camera, it claims the QR code inside the lock’s battery door is incorrect.
It then says it will pair without encryption. It then gets stuck on the processing/loading popup and never does anything (Ezlo is changing colors).
After waiting forever for it to do something, I pulled the power to the Ezlo and plugged it back in. I unpair and re-pair, and choose to enter the code. I enter the first 5 digits fo the 40 and hit next/ok (or whatever that button was to go to the next). It then gets stuck on the processing/loading popup and never does anything (Ezlo is changing colors).
After waiting forever for it to do something, I pulled the power to the Ezlo and plugged it back in. I unpaired the lock, and re-paired. Then I choose “other” for pairing and chose not to encrypt. The processing/loading popup appears for a few seconds and it suddenly goes right back to the “Devices” screen. Nothing happens/happened.
I then go back and do it all again with the exact same results on each step.
Side note: VeraPlus will no longer pair OR unpair this lock either suddenly. The lock works fine with its Danalock app, and it pairs with another non-vera/ezlo hub just fine (without encryption), and it used to work with the VeraPlus just fine. I don’t know if that has something to do with it as well (maybe its a shared update in both firmwares or something).
