are you using the generic ZigBee to connect with Hue? I was looking something similar to the plugin available in Vera that connects directly to the Hue Hub
Generic zigbee, no plugin needed. Also, if you take care using touchline (*), you can include bulbs into the Ezlo and your hue hub simultaneously, so you can still control the bulbs through the hue app.
At the same time, there is another option to control the hue system using VOI on top of Google or Alexa. This however does not offer local control and will be dependant on Cloud, while the first options works fine without any internet connectivity.
*: e.g. trough the hue essentials app.
Thanks jouked, with this method though I wont be able to see the color scenes that I created in the hue hub, right? Would need to re-create all of them in the ezlo app, one by one?
BUG
Lastest Vera app version 7.50.690 connected to my production Vera Plus, Dashboard flickering and tiles changing from one device to a different device.
Android 9 Pie Huawei phone.
Bug report
https://jira.mios.com/servicedesk/customer/portal/72/ECS-422
By pairing directly, youâre bypassing the hub thus youâre not able to reuse Hue scenes. However, using VOI you should be able to address existing hue scenes, rooms etc.
If you want, you can use both options together, VOI to control scenes, local devices to control a single device.
Can somebody confirm if this is an issue just with me or its bug with IOS app or its a bug in Ezlo plus in general.
when you create a scene from a switch and you select when switch is on, it says âWhenever switch state changed: Onâ save the scene go back in the scene and it says âWhenever switch state changedâ
Any update on the creation of scenes with a âin between time intervalâ condition?
Iâd like to hear too. Iâm running into the need to put time restrictions on my scenes, and canât figure out how to do it.
TKB TZ77 RGBW not detected correctly as an RGBW device instead its just a dimmer with no colour controls on the parent device.
To be fair the Ezlo Plus hub has included and handled this device exactly the same as the Vera Plus did back here.
However on Vera in the web GUI I can change the devices file templates to make it have a colour picker on the parent device.
device_type:
To: urn:schemas-upnp-org:device:DimmableRGBLight:2
device_file
To: D_DimmableRGBLight2.xml
device_json
To: D_DimmableRGBLight2.json
This screen shot from Vera Plus:
I cannot NOT do this with an Ezlo Plus hub as there is no web GUI and no way I am aware of to change the devices template files. So this TKB TZ77 RGBW module is a useless brick on the Ezlo platform as far as not having a colour picker.
Here are some screen shots for the Ezlo Plus and the Vera mobile app.
There is one parent device a Dimmer and 4 child devices, one for each colour channel RGBW. The child devices do work as in they do control each colour channel.
But Iâd like a colour picker on the parent device please.
Bug Tracker report:
https://jira.mios.com/servicedesk/customer/portal/72/ECS-427
Sounds like your making progress. Personally I would never count on having one device control something directly through the zwave network. My approach would be to let a thermostat do the controlling directly, and set it via my controller. I just donât want to trust the network for controlling key things like house temperature. To each his own though. So direct control between devices is not al issue for me. The inability to select temperate scale seems like something that should of been enabled early on in design. My EZLO plus is due to be shipped out later this month, and then Iâll join in on the conversation here. Wondering how well locks are supported. Also have a wifi EcoNet thermostat that I have never been able to integrate, although I have it set up on my Alexa.
Qubino DC Flush Shutter - ZMNHOD1 (EU) doesnât pair correctly with the Ezlo Plus.
I believe ZMNHOD3 is the US version of the same device.
Just unpaired the module from the Vera Plus and paired it to the Ezlo Plus.
Its done something very strange and added it as five devices not two, as I have the temp probe connected also.
I have 3x Window Covering devices named:
Flush Shutter DC
Flush Shutter DC 1
Flush Shutter DC 2
And I have 2x temp devices named:
Temperature Sensor 1
Temperature Sensor 2
If I press the Close button on the âFlush Shutter DCâ device the blind starts to move down.
âFlush Shutter DCâ device is showing at 100% the other two devices are showing at 0%
If on the âFlush Shutter DCâ in the Vera mobile app I go to Z-Wave settings it says status Synchronized what ever that means? However it does not list any parameters at all that it may have detected.
I canât seem to add any parameters myself also. If I press the Reset button on this page nothing seems to happen. Also if I âRediscoverâ device it still doesnât list its current parameter values or allow me to add any.
Bug Tracker Report:
https://jira.mios.com/servicedesk/customer/portal/72/ECS-431
Android app and Ezlo Plus versions
Also it says relay connected shouldnât that say local?
Also on the Vera Plus when you add a new device and search for âQubinoâ there are various device setup wizards including one of this DC Shutter module.
However on the Ezlo Plus when you do the same there are no device setup wizards listed.
I have seen this with other Z-Wave devices also. Is Ezlo moving away from dedicated device setup wizards ?
Iâve unpaired the module from the Ezlo Plus and paired it back on to the Vera Plus and that also has various extra devices, I must have hidden these extra devices from the UI7 web GUI and forget it did that after pairing.
So it doesnât pair correctly on the Vera Plus either. âLounge Blindâ is the parent device.
Canât edit a Lua script in a scene?
Just create a scene with a lua script.
I wanted to edit the scene and edit the script I created but how?
I only seem to have an option to delete the existing script but not edit it.
Actually the delete option only removes the script from the scenes Actions it doesnât delete the script itself.
So I canât seem to either delete or edit an existing lua script.
OK deleting the entire scene seems to have also deleted the Lua script.
So my first question stands how do you edit an existing Lua script added / created within a scenes Action.
OK so Lua scripting on Ezlo is going to be somewhat different.
This script blinks a light on and off.
device = 291 -- Blink Globe Lamp
count = 4 -- number of times to blink
rate = 2 -- number of seconds between blinks
function blink_on()
luup.call_action( "urn:upnp-org:serviceId:SwitchPower1", "SetTarget", { newTargetValue="1" }, device )
luup.call_delay( 'blink_off', rate )
function blink_off()
luup.call_action( "urn:upnp-org:serviceId:SwitchPower1", "SetTarget", { newTargetValue="0" }, device )
count = count - 1
if count > 0 then
luup.call_delay( 'blink_on', rate )
-- Start blinking
blink_on()
Obviously the device IDs are different and I can look up this devices ID using the Online Api tool.
But what about the luup.call_action calls?
Assume âurn:upnp-org:serviceId:SwitchPowerâ no longer exists in the Ezlo Api, so whatâs the equivalent?
Please check the settings, for Lua Scripts section,where you can add/test/edit/delete scripts.
Can you convert the script above to an Ezlo one as an example ?
I would like to see an example too. For me there are too many unknowns to even start. Like, can a scene control a zwave gateway device from Lua? I know a plugin cannot. I am no longer willing to experiment for days to only find out it is not (yet) working. I wasted far to many hours on Ezlo like that already. So please show working examples when you release new functionality and include documentation.
Cheers Rene
Totally agree Rene.
We now have Lua scripts in Ezlo scenes but I donât know how to even create scripts that will work or what is possible ?
I know how to create Lua scripts on the Vera platform.
Maybe @Sorin should create a new Forum section dedicated to Ezlo Lua Scripting and examples. And for Ezlo to give us some examples and documentation.
Great thanks we just need some working examples now to get us started.
