Thanks @lord55 , @Odysee . It is always better to use Feature and Bug Tracker meanwhile you can mention your ticket here also. Thanks for your interest and support.
Thank you…soon we will be releasing an IOS app (android to follow) that will allow you to display dashboard in Kiosk mode (full screen)…so you can use this app to put a Tablet on the wall to display the dashboard! And you can design any dashboard you want.
this will be the screen you see when you click create a dashboard…
you can drag and drop widgets from the left bar and use the right hand bar to modify them etc.
Hi @cw-kid , Yes “Reboot Ezlo” does reboot the controller. It uses internal API call for it.
“Remove Ezlo” removes the controller from your account. So you need to add it again using mobile app.
So I created an example show case to demonstrate the new HTTP capability in EZLogic, which many old users are used to, using Telegram as a notification tool. It may be useful for new users.
Awesome, this is amazing. Now I can load my automation plugin but I have a problem, my controller has not been updated to firmware version 2.0.23.1817. Could you help me with this? and what programming language would these plugins work on, will it still be .lua?
