Excellent, and would you also use the D.json (device), D.xml (device), I.xml (implementation) and S.xml (service) files?
No they are no long using those like Vera firmware hubs.
We’ll provide full documentation with samples and a blank template of a plugin…
so that you can take it and design anything you want…
Ohhh!! i get it ![]()
Perfect, I will be aware of that documentation, I am so interested in installing my automation plugin in this new controller to see its behavior. Thanks!
How to build your very first MeshBot tutorial.
Hi @JoseC check out our initial version on plugin documentation and sample plugin pls.
Awesome, Thanks!
