Updates for EZLogic - 1.40.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com/
Previous: Updates for EZLogic - 1.39.1 (Ezlo Hubs only)
Cloud MeshBot. Trigger. Cloud Variables.
Added “Current value” label for Cloud Variables. When you select a Cloud Variable in Cloud MeshBot you will see its value.
In case of long values, you could hover it:
We provided ability to compare Cloud Variables vs Cloud Variables. It’s possible to use them as left and right side comparators.
Note: Device vs Cloud Variables - next in line.
Local MeshBot. Trigger. Expressions as a left side comparator.
We added Expressions in Trigger section as a left side comparator.
Let’s create an expression first:
Then, use it in the trigger:
Note: Local Variable as left side comparators - next in line.
Customization. Notification and Interaction Flow MeshBots.
In addition to Cloud MeshBots we apply customization to Notification and Interaction Flow MeshBots. Customization will be applied to Trigger section only.
Note: Action section will be ignored as it contains only single node for both MeshBot types.
Fixes and Improvements:
- Fixed validation for Triggers in Cloud MeshBot in edit mode.
- Fixed input for “string” capability type in Trigger section in Cloud MeshBot.
