Updates for EZLogic - 1.37.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com/
Previous: https://community.ezlo.com/t/updates-for-ezlogic-1-36-1-ezlo-hubs-only/219871
Cloud MeshBot. Actions. NuCAL node
In addition to Local MeshBot in the previous release, we changed UI representation for Cloud Variables in Cloud MeshBot.
In case if you want to extract specific element from the array (1), you should type the index in the input (2) and then drag and drop the property. By default it will have the name as “items [index]” (3).
Cloud MeshBot. Trigger. Cloud Variables
We changed Cloud Variables node in Trigger in Cloud MeshBot.
To select a variable before, you had to select a service, your account and then a variable.
Now, you will see all your Cloud variables under the same field.
Complete trigger will look like:
Note: Changes for Local MeshBot are in progress.
Local MeshBot. Action. Controller node
We are glad to announce Controller node in Actions in Local MeshBot.
It has Reboot and Reset controller capabilities.
Reset controller has two values.
Soft reset - will restart a hub.
Factory reset - will restore a hub to its original state by erasing all of the information stored on it.
Fixes and improvements:
- Fixed right side comparand value type for “string” capabilities in Local MeshBot.
