Updates for EZLogic - 1.34.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com
Previous: 1.33.1
Local MeshBot. Date and Time. isOnce node
We added a restriction for isOnce node. It is not possible to combine isOnce node with other Date and Time subnodes using “AND” operator. In case if user tries to select other Date and Time node he will see the warning:
We don’t have this restriction on different trigger levels and for “OR”, “XOR” operators:
Local MeshBot. Date and Time. isInverval node
We added a check for isInverval node. It was not possible to combine isInterval with other Date and Time nodes on the same trigger level.
Since advanced_scenes: 1.55 it is possible to use it with other Date and Time subnodes.
Fixes and Improvements:
Display missing isOnce fields on MeshBot page in Edit mode.
Thanks!
