Updates for EZLogic - 1.17.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com
Previous 1.16.1
Local MeshBot. Trigger. Expression value
As you know it is possible to use an expression as right comparison operand. To create an expression:
  • Go to Expressions page
  • Click “Add new expression” button
  • Provide “name” and valid LUA code.
    Note: if you add link to device’s capability, do not forget to return it.
  • Click “Create” button.
Then use the expression as right side comparison operand. You can see current value of it under expression “value” dropdown.
Fixes and Improvements:
  1. Fixed MeshBot editing page if MeshBot uses removed MeshBot in Trigger or Action sections.
  2. Fixed validation indication bar in Local MeshBot.
  3. Fixed validation for “Between”, “Not Between” operators in Triggers.
  4. Cleared capability and value blocks after Device switching in Triggers.
  5. Cleared expressions and value blocks after Capability switching in Triggers.
  6. Fixed app crashing for NuCAL node in False Action section.
With 1.18.1 when you select a MeshBot as action the selection menu is too narrow:
When selecting “At a time of the day” there is no option to choose the day (like with the other options after, between, before):
