Updates for EZLogic - 1.1.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com
Previous: 1.0.1
Features:
1. Info Buttons
We introduced info buttons for MeshBot nodes and UI elements.
You can read the description of specific node or UI element.
Just click on the info button (1), you will see title (2) and description (3). Also, you could find the link (4) for further reading. We are going to cover more UI elements and add more links to the Help center.
2. Date and Time. Input sanitization
Prevented negative, non-integer numbers.
We are still working to provide better validation rules and sanitization for all input fields in the app.
3. Device settings. String type
Added support for “String” type in Device Settings.
4. Lua Scripts. UI changes
Made table left aligned
