OK. You say currently, so it might change in the nesr future?
And what about the tiles in agroup, can vertical alignment be changed to top in stead of center?
What’s your preferred format for this field?
What format do other apps use?
Do they give you the ability to customize the format?
Use the HorizontalContentAlignment & VerticalContentAlignment properties on the DeviceBrowser control to update the tile arrangment. A VerticalContentAlignment of Top will shift the tiles to the top in your Group.
Preferred is all tiles at the top and starting from left. My question was meant for the standard group collections and groups that are made when you added devices (as in my case several Vera controllers and a Fibaro Home Center.
I know you can make your one pages with custom made tiles and using the DeviceBrowser. Maybe I will do that later on.
Don’t get me wrong: Home Remote is a fantastic app. My standard app was Imperihome and there you can choose for different page formats (with a lot of smaller tiles or big tiles or combinations).
It would be nice if you could tweak the display of these standard groups but it is not a big deal.
@cw-kid@bill_v I have added 4 devices to one of my Vera controllers. I performed a “synchronize devices” on this controller in The Home Remote but these devices don’t show up. I have repeated it at least 4 times. What goes wrong here ?
Seems to work OK for me initially at least when first adding. I created a new blank project and added a Vera object and it has both my Vera Edge and Vera Plus hubs with devices and scenes present from both.
It also added objects for my Ezlo Plus and Ezlo Atom serial numbers. But obviously these don’t work and show any devices or scenes.
it is certainly possible to replicate imperihome formats utilizing Device browsers. It is also possible to have different tile sizes within one Device Browsers.
Initially Home Remote automatically added all my Vera controllers with all their devices and scenes. And indeed also my EzloPlus was found but with no devices at all.
The issue I have is that I added 4 new devices to my Master production Vera and when I perform synchronize devices on this Vera controller the new devices are not added
I just reloaded the LUUP Engine on the Vera Edge and now my new “Test Bulb” device has appeared in the Home Remote designer after selecting to Sync devices on that hub.
