ZWave
1 All current Fibaro products Current Progress
2 All current Qubino products
3 All current AeonLabs products
4 POPP products, german company bought by AeonLabs and have special products like Keypad, Module for door locks, Rain Sensor, Valve Controller etc…
5 Greenwave powernode 6 with energy measuring on each single node (powernode plug and strip)
6 MCOHome Fan Coil Thermostat (MH8 series)
7 ZWave: Neo Coolcam
8 All MCO Home Devices (also Switch Panel (serie 310, 410, 510)
9 Dimmer Panel
10 Shutter Panel
11 Air Quality Monitor
12 TOPVICO Motion Detector
13 ISURPASS KeyPad
14 HEIMAN CO Sensor
15 Smoke Sensor
16 All REMOTEC Devices ( zxt-600 )
17 HANK Scene Controller
18 Heiman (smoke co2 etc) http://www.heimantech.com/product/smart_zwave.html
19 They have fan coil thermostat https://www.heltun.com/z-wave-fan-coil-thermostat
20 Heating Thermostat https://www.heltun.com/z-wave-heating-thermostat
21 Light switches https://www.heltun.com/z-wave-touch-panel-switch
22 High Load switch https://www.heltun.com/z-wave-high-load-relay-switch
23 Relay Switch https://www.heltun.com/z-wave-relay-switch-quinto
24 iBlinds window coverings
25 Danalock Devices
26 Telldus Devices (Telldus magnet sensor)
27 Nexa (Swedish) Devices (Nexa in-wall dimmer)
28 HeatIt series
29 Sunricher series (They are widely re-branded. Ex the HeatIt push-buttons are re-branded Sunricher devices)
30 NeoCoolCam ZWave devices (Tuya)
31 Inovelli Switches (LZW36 - not yet on the market, LZW31-SN)
32 TKBHome products (TZ74, TZ37)
33 All Sunricher Zwave devices
34 Zooz ZEN16 for Garage Doors, Sprinklers, Gas Fireplace
35 Netatmo Smart Radiator Valves, Netatmo Prescense, Netatmo Welcome
Zigbee
1 Hue lights
2 Hue power plugs and motion sensors
3 IKEA zigbee products
4 Yale Doorman (Europe)
5 Xiaomi Door Window Sensor Pocket Size Xiaomi Smart Home
6 Xiaomi Temperature Humidity Sensor Zigbee Wireless Intelligent Mini Environment Detector
7 Xiaomi Mijia Wireless Switch
8 Zigbee 3 profiles (I could care less about non-standard devices at launch, support the stock profiles)
9 Sengled Lights
10 Sonoff (new cheap zigbee devices SNZB-01&02&03&04)
11All Sunricher Zigbee devices
12 Aurora AOne range of Zigbee lighting products
13 Eaton Halo RL56 Integrated LED downlight
Cloud Integrations
1 Nest Devices (Thermostat, etc)
2 MyQ Garage Door
3 IFTTT
4 Weather service with forecasts
5 Ecobee thermostats (even better if done locally via WiFi!)
6 IKEA gateway
7 Tuya
8 Sonoff
9 Broadlink
10 Xiaomi/Aqara
11 Shelly
12 Google home
13 Home kit
14 Alexa
15 Google assistant
16 email (ability to send mail directly, including from gmail)
17 Bond home. Very similar too an ir blaster.Bondhome.io
18 Tesla cars (API)
19 Netatmo cameras (API)
WiFi Integrations
1 Logitech Harmony Hub / Remotes
2 Broadlink IR blasters
3 MQTT
4 Sonos including TTS
5 Multiple Solar panel systems, some are cloud based [need specific examples pls]
6 Gogogate 2
7 TP Link Wifi switches
8 Netatmo Weather Station and Thermostat
9 Switchbot
10 Honeywell WiFi Thermostats
11 Tempest Weather System
12 Tuya compatible wifi products IR, switches, sensors
13 AVM Fritz!BOX (incoming calls, call number, …)
14 IP-Control for AV equipment (TV, PVR, AV-Receiver, …) e.g. to stop movie when doorbell is used
15 Home Connect (home appliance devices from Bosch, Siemens, Neff, Gaggenau)
16 Doorbird Doorlock and Doorbell
17 Fronius solar inverter (API)
18 Flume water meter
2Gig Integrations
1 2Gig glass break detector
2Brel motors for roller blinds. In the RFXcom it is configured under Blinds1 T6 DC106,RMF,Yooda,Dooya,ESMO,Brel.
3 Cresta TS34C
433 RFX comm (or support the RFXComm plugin natively)
1 KiKa
2 Somfy screens
3 433 mhz (now via RFXCOM):Weather sensors Oregon, TFA, cresta,…
4 USB RFXtrx433
Plugins
1 Reactor
2 Switchboard
3 Alexa TTS
4 Virtual http switch
5 Honeywell Evohome (zone heating)
6 RFXCOM (hundreds of 433 mhz devices connectable)
7 Milight (cheap version of Hue but works great)
8 Paradox
9 DSC alarm panel support
10 Datamine
11 Weather (something that includes national weather service Watches and Warnings in a way that can be used as triggers)
12 multiswitch - or some other virtual button/device feature
13 Pluggins: VeraAlerts (+ PushOver)
14 Netatmo
15 MySensors (https://www.mysensors.org/)
16 GCal3
17 Switchboard
18 AltHue
19 SonoS
20 Synology Surveillance Station Remote
21 Syslog
22 VeraAlerts
23 ALTUI
24 IPhoneLocator
25 Emby media server
26 VeraFlux (local database storage)
27 Variable container (Replaced by this)
28 Smartthings Appliances
29 Open Sprinkler
30 Rachio irrigation
31 Logitech Harmony Hub plugin
32 NetworX/CADDX security panel plugin
33 iKettle (plugin)
34 Solar Meter (plugin)
35 Power Arithmetic (plugin)
36 Virtual ON/OFF Switches (plugin)
37 Powermax
38 Datamine
Other
1 Insteon/X10
2 Camera RTSP (setup, control, motion detect and image capture with notification)
3 Server-side (Mios?) power/internet outage notifications when contact lost [need more info pls exactly what you want to achieve with this]
4 Ezviz/Hikvision cameras and doorbells and ability to store few recordings on ezlo
5 Node-red full intergration
6 Decent code editor/tester
7 Google firebase cloud messaging
8- https://www.openalpr.com/
9 Object, Face detection (Camera)
10 Zipato products, They have a fantastic RFiD Keypad
11 Danfoss living connect
12 OOMI (OEM of the Aeotec)
13 Konnected Alarm Panel
14 Tempest Weather Station
15 KNX
16 The ability to send post/get web request with webform or json body, Without coding.
17 smart TVs
18 data stores to store history of metrics / events
19 CGE IPX relay card : GCE Electronics Module Rail DIN Webserver 8 relais IPX800 V3.0
20 Cartelectronic WES server : Serveur W.e.s. v2 - Cartelectronic
21 DSC Powerseries alarm (neo )
22 better notification and log system. would be helpful to view past logs of devices running scenes or what lights went on. Also being able to send push, mail, sms notifications to different users for different events
23 Tibber Energy Company for best electric prices. Forget everything you know about energy companies ⚡️ Tibber
24 Local media server, https://volumio.org can be downloaded on any machine (mine on rpi), you can upload your own mp3 file and run them using web page interface or their app (charged). [ more than 500 web radios from all over the world + airplay your audio files from your ios device] Volumio Documentation
25 System Logging
26 Blue Iris (Video Management Software)
27 AV receiver integration (yamaha)
28 Google TTS
29 Xiaomi Mi Home integration
30 Adding virtual motion sensors pulling motion detection events from the Hikvision cameras alert streams The plugin / implementation file reads the Hikvision cameras alert stream information looking for motion detection events these control the virtual motion sensors in Vera.
31 Be able to add camera video streams for viewing into the mobile dashboard app, either rtsp or mjpg.
32 Generic 16 channel CCTV units
33 SIP IP intercoms /videodoorbels
34 IP cameras with audio in/out, motion detection, PTZ
35 SmartThings devices and sensors
36 Russound RNet Series
37 EnOcean USB300 Transceiver
38 Leviton LevNet WSC04-IRW Leviton LevNet WSC15-IRW Leviton LevNet WSC12-M9N Leviton LevNet WSWDR-H9W Leviton LevNet WSWDR-I0W
39 Integration to the European smart power supplier Tibber
40 All PLEJD products (Swedish brand of smart bluetooth dimmers and switches)
Our development team will take these requests and get it done as soon as possible. Ezlo Platform wants to integrate everything that is commercially available within the zwave, zigbee framework and integrated them fully and properly!
