Tell us which integrations you want us to make for the EZLO PLATFORM please
Google home
Home kit
Alexa
Wifi: Gogogate 2.
Zwave:
Greenwave powernode 6 with energy measuring on each single node (possible on all platforms/controllers except Vera…)
433 mhz (now via RFXCOM):
Weather sensors Oregon, TFA, cresta,…
Plugins (or native integration):
Honeywell Evohome (zone heating)
RFXCOM (hundreds of 433 mhz devices connectable)
Milight (cheap version of Hue but works great)
Integration for home assistant like vera already has.
Question for the guys who listed ā€œHueā€ (lights, plugs, sensors, switches, etc.)…
Are you envisioning the ezlo platform taking on-board ALL of the features and coordination currently handled by the Hue Hub directly via Zigbee (thus eliminating the need for it?), or simply connecting natively to the Hue Hub via HTTP/API (thus eliminating the need for a HueX plug-in)?
IP / WIFI
Logitech Harmony Hubs and Remote Controls
With regard to Harmony hubs / remotes, we currently have the excellent 3rd party Harmony plugin for Vera by @rene
The Wiki for the plugin can be read here
The forum page for this plugin can be seen here.
The release notes for the plugin can be seen here.
Instructions on the plugins configuration and features can be see here.
This is a very powerful plugin and the Harmony integration with Vera is very in depth and tight.
It even exposes a local http api that you can use to send http commands to Vera which will in turn relay those commands on to the Harmony hub to control your IR devices / button commands for those devices on that Harmony hub etc.
I have used this feature to add remote control ā€œbuttonsā€ in to the Imperihome app and also in the Yatse Kodi app and in to other mobile apps I use as well that support sending http commands out.
Without this Harmony plugin on the Ezlo platform, I would have to seriously think twice about migrating to the Ezlo platform without it.
The plugin is fully featured and does everything you could want with integration in to Vera.
Here are my Lounge Harmony activities in Vera UI7 and also an IR coloured lamp I have in the lounge that is controlled by the Harmony hub for example.
However to my knowledge there is one thing that you cannot do either by using this plugin or native support from Vera Control Ltd.
Logitech Harmony has a feature called ā€œHome Controlā€
Some of the Harmony remotes have special ā€œHome Controlā€ buttons for controlling either lights or appliance plugs etc.
Also on Harmony remotes with an LCD screen these ā€œHome Controlā€ devices are accessible and controllable from the remotes screen and also from the Harmony mobile app.
Natively only a few smart home platforms are supported by Logitech Harmony, the main ones being Philips Hue and SmartThings for example.
In the MyHarmony desktop software you can add a compatible ā€œHome Controlā€ device such as a Philips Hue bridge or a SmartThings hub.
This would then expose all of those smart home devices in to the Logitech Harmony ā€œHome Controlā€ function.
In the MyHarmony desktop software under Devices - Home Control - I added the HA Bridge aka the Philips Hue emulator.
So to do that, I am currently using a 3rd party solution to get certain Vera Z-Wave lights and appliance plugs in to the MyHarmony software and on to my Harmony remotes, so I can control these Z-Wave devices from my Harmony remote control handset.
I am using the JAVA HA Bridge software running on my Windows file server.
This software acts as a Philips Hue bridge emulator.
I can add certain Vera Z-Wave devices or even Vera scenes in to the HA Bridge by using Vera’s http local control api.
Here is an example of a Fibaro Dimmer 2 Light for my Kitchen ceiling and how it is added and controlled in the HA Bridge software using Vera’s http api.
Any Vera devices or scenes I have added to my HA Bridge setup, those devices are then detected and added in to the Logitech Harmony ā€œHome Controlā€ feature.
I would like to see native support from Ezlo for Logitech Harmony ā€œHome Controlā€.
And I would definitely like to see the current 3rd party Harmony plugin for Vera ported over to the new Ezlo platform if at all possible.
Elzo have stated that for popular 3rd party plugins if the original developer is not active or unable to recreate their plugin for the new Ezlo plaform, then Ezlo themselves would look at undertaking that work.
Either really.
However I am happy to keep my Hue bridge and have native support in the Ezlo hub to control my Hue lights via the Philips Hue api, as I do now with the Alt Hue plugin for Vera.
Zipato products, They have a fantastic RFiD Keypad
Danfoss living connect
OOMI (OEM of the Aeotec)
TP Link Wifi switches
Fibaro Event data! (error messages, status messages and so on…)
Glad you brought it up, I was going to post thread today about the same subject :slightly_smiling_face:
I have been looking around to see what is really missing from vera/ezlo platform, at least what I am using and (what I think) most important devices should be covered for your customers to have a unique smart home system.
1. I would begin with MCOHome Fan Coil Thermostat (MH8 series) which is already integrated into vera, but still its not full integration (mentioned it before and sent email to support) regarding the fan stage (High - Medium - Low - Auto), since you guys made it work why not adding this feature?
IMG_DFF477D06618-1
This is how it look like now, I hope ezlo team can complete the integration by adding fan stages please.
2. Another device we have been promised (or voted to make it happen) to be integrated which is Konnected Alarm Panel, Konnected works seamlessly with some of the smart home systems but why not ezlo? I have been looking for simple smoke alarm systems to work with vera but I could not find one, the wireless battery powered devices are not taste, so please consider it.
konnected
3. How you can have a smart home system without your own weather station telling you the current weather status from your home! I really recommend Tempest Weather Station, its still funded on indiegogo and they started the production already, going to receive mine next month, take a look on which smart home systems it will work.
TEMPEST
The same question should be asked again, why not ezlo?
https://weatherflow.com/tempest-weather-system/
https://www.indiegogo.com/projects/tempest-a-revolutionary-personal-weather-system/x/13776982#/
4. One more thing, atmoshome.com the smart screen dashboard, they are saying that their screen is compatible with vera and other smart home systems, btw the way they promised to deliver the screens to their customers back in Nov 2019, but I think they went into financial difficulties and they are raising a crowd funding again, it looks promising and I hope they can make.
We have a fully customizable dashboard coming up very soon…you should be able to utilize it instead of Atmoshome hopefully.
But what about the other devices I mentioned earlier?
all added already (I edit the original post by adding all the requests there)…Please check the original post on top to make sure everything is there for you.
Thanks, btw the mcohome thermostat is a z-wave device.
I only have one to add.
KNX
DSC alarm panel plugin was the main driving force to go with Vera and still is today. Whatever my next platform is, support for my alarm panel is mandatory. The fact that my HA can leverage all of the alarm system devices and sensors, is really a plus.
DSC alarm panel support.
Plugins (or equivalent ezlo feature)
*Reactor (I historically used pleg but Richard seems busy with life)
*Datamine
*Weather (something that includes national weather service Watches and Warnings in a way that can be used as triggers)
*multiswitch - or some other virtual button/device feature
Local Integrations
*DSC security panel
*Zigbee 3 profiles (I could care less about non-standard devices at launch, support the stock profiles)
Cloud
*alexa
*google assistant
*iftt
*email (ability to send mail directly, including from gmail)
And I would vote against special effort for products from defunct manufacturers or that are no longer available except as surplus (e.g. greenwave powernode 6, of which I own 2).
Great list, keep up the good work. Once this is all in I’am even willing to pay for it :wink:.
Oeps didn’t see anything on graphics like Datamine or similar, would really be handy to have some graphs in that also integrate to the new dasboard.
Looking at the very start of the thread, I still don’t see some of the proposed (specially for EU) devices:
ZWave: Neo Coolcam
Cloud: Alexa, Google Assistant
Pluggins: VeraAlerts (+ PushOver)
The ability to send post/get web request with webform or json body, Without coding.
