No, have not heard about that. Some details from the log file could show what is going on. I have both on a single Pi with openLuup without issues.
Cheers Rene
Cheers Rene
Thanks for your reply. I reinstalled MWS with no adverse impact on Reactor. However MSW is not operating. The parent device reports: Waiting for Luup reload & No data. There are only 2 log entries. The first is āDevice:Multi Weather Station (#77) in incorrect authentication informationā. The second log entry is āDevice responding againā. I placed my OpenWeather key in the Provider Key field of Settings and selected Current Temperature and Wind as Display Lines 1& 2. Any idea what I am doing wrong or what I should try next? I am running a Vera Plus.
Make sure you configured your credentials and hit Save Settings. Your hub should then reload LUUP to connect. Else send me a PM with all the log entries for the device.
Thanks again and sorry if I am being a pest. Uninstalled, rebooted Vera and reinstalled MSW. No impact on Reactor. I did not configure any fields other than Weather Provider and Provider Key. This time the parent shows Waiting LUUP Reload. CTL F5 fails to clear the Waiting LUUP Reload. The MSW parent logs have just two entries. The first is āDevice:Multi Weather Station (#87) in incorrect authentication information. alert: #45867791842ā. Approximately 3 minutes later is the second log entry āDevice:Multi Weather Station (#87) in is responding again. alert: #45867825492ā. I then moved the parent from āNo Roomā to āSP Weather Roomā This cleared the āWaiting LUUP Reloadā. Now it just says āNo dataā and "No data. Then I changed Display Line 1 and Display Line 2 in Settings to Temperature and Wind respectively. MWS still reports No data and No Data. There are no additional MWS log entries. When you say ācredentialsā, does that mean more that just putting my API Key in the Provider Key field the case of OpenWeather? If so, what other fields do I need to configure? Is there some documentation that I have missed? Which logs are you referencing MSW or Vera? Itās been years since I accessed Vera logs.
I am a pure novice when it comes to Vera logs, but I rebooted to get a new log starting point and did a search on MWSās device number. I found the following two errors in in the logs in proximity to MWS log entries: āluup_require canāt find cjsonā and āluup_require canāt find zlibā. Can these missing modules be the problem? If so, how do I correct it?
Those modules are optional, not available on Vera, but are there on openLuup and make things more efficient.
After some initial research I think OpenWeather will not work on Vera any more. The firmware is very old and lacks any modern security options that most web sites require today. Not sure if a workaround is possible, but to be honest I do not plan to research and implement that for Vera as it is end of life.
Cheers Rene
When @retireditguy started this thread, I actually tried installing it myself with Reactor to see what, if any, conflicts there might have been. It all worked fine for me, but at that point, it seemed he had uninstalled so I didnāt post about it (sorry about that; wrong choice). Anyway, I saw no conflicts between Reactor and MSW (and I even did a quick code review on MSW on Github to see if anything stood out that might be a problem, and itās whistle clean).
@reneboer My test was run on my venerable old Vera 3 (one Plus lives on the shelf now, and the other is house/production, so isnāt used for experimentation). Even that ancient 1040 firmware had no trouble getting OpenWeather data, so it looks to me like it still works for the moment, and therefore should also work on the slightly more modern 7.3x family on the Plus/Secure. The Edge is sometimes a bit of a tweener; itās not built exactly like 3 or Plus, so YMMV, but Iād expect closer to Plus (and therefore still working as well).
Edit: To add, @retireditguy , if youāre not on the latest Reactor from Github, please do upgrade. There are some relevant bug fixes. I no longer publish my plugins through the Vera App Marketplace; that became too inconsistent to deal with some time ago, so Iāve given up.
Thanks for your reply and the heads-up on Reactor. I will upgrade both Vera Plus units as soon as I have a few minutes. I am a bit confused regarding the cjson and zlib errors in the Vera log. If these modules are optional, why are they reporting as luup_require canāt find in the log? Also, do I understand that you are able to run MWS successfully on and old Vera 3 and you believe it should run on a Plus? Did you need to enter any data other than the OpenWeather API key in the MWS settings or elsewhere? Thanks again for your assistance. The "conversion to ezlo is definitely a pain.I purchased an ezlo plus and this whole exercise is like starting from zero. I suspect MSR is in my future. Did I read that you have successfully ported it to ezlo?
Is MWS available on ezlo? Also, referring back to my earlier post, does configuration of MWS require entering any data other than the OpenWeather Api key, for example, ID and password?
This is really a @reneboer question but it has a generic cause so Iāll answer on his behalf: in order to see if the library is available, you have to attempt to load it. You canāt stop the log message if the load fails, but the failure doesnāt cause the plugin to stop; itās a ācontrolled crashā. The message can be safely ignored. If MWS were my plugin, I would probably not attempt to load these if I knew I wasnāt running on openLuup, because thatās the only system on which these libraries would likely exist.
Correct.
Nope. I just popped in my API key and it worked immediately.
Itās not a port, itās a whole new thing, and it does work with Ezlo (Plus, Secure, and latest-generation Atom).
if Weather is of interest, then Ezlo has a built in capability to provide Weather, as well as connectivity to other weather servicesā¦
you can see how I got the temp in New Yorkā¦
and I even simply dragged and dropped the ātempā into a ācloud variableā so that I can use this variable in any other MeshBot I createā¦
Thanks for your replies. One last question, did you install MWS from the Marketplace or from Github?
Thank you very much for the āheads-upā. I am a retired IT executive and a long time Vera user, but only recently purchased an Ezlo Plus. I have to admit, I find the impending āmigrationā to Ezlo intimidating, mostly because I donāt yet understand all the parts of the new architecture including ezlogic and Nucal. (Waiting for the announced device migration toolkit.) The only āprogrammingā I have done in the last 10+ years was Vera and Reactor scripting. I am glad to see that Ezlo is building some meshbots for general use by Ezlo owners. Is there or will there be documentation regarding the individual meshbots? For example, I āinstalledā the Ezlo Weather and Open Weather meshbots and was able to recreate your āGet Temperatureā example. However, itās unclear to me how I can modify the OpenWeather meshbot to obtain additional data, specifically humidity and wind speed. Can you provide any suggestions on where to start learning how to interact with the Ezlo, especially Mios/ezlogic.com?
Lastly itās hard to believe you have the time to participate on this board. You must be really committed to Ezloās success.
1000%!
I am selfishly building the last ever home automation I want to use in my home
Hello @retireditguy
You can find documentation on Ezlogic and meshbots here.
Regarding your question about getting other variables other than temperature, Iām not sure these integrations give other data. Iāll check if thereās a way to do it.
Hi @retireditguy and @reneboer
Iām rebuilding a VeraPlus and looking to get out from under the impending Darksky shutdown by switching to openweathermap.org using MWS. Looks to me like the current MWS version is using a non-free API call - āonecallā. I get the authentication error too if I just run the query in the browser, or in the plugin of course.
The version 1.1 of the MWS plugin seems to call the non-free API. Looks like its on line 918 - L_MsWeather.lua if Iām reading it right.
The current free api is user āProfessional Collectionsā and has a certain rate/limit you can access the weather data (which is pretty high for free use - 1 million calls/month).
Ideally the URL would look more like: https://api.openweathermap.org/data/2.5/weather?lat=%s&lon=%s&units=%s&lang=%s&appid=%s&exclude=hourly
ā¦but Iāve tried this - also to no avail - but the browser response comes back successful.
Iām not quite sure how to debug further. Tips would be welcome.
Replying to myself with more data:
luup_log:86: Multi Weather Station_debug: Calculated next poll at 2022-12-04 19:04:30 in 60 seconds. <0x7473c520>
06 12/04/22 19:03:30.101 Device_Variable::m_szValue_set device: 86 service: urn:upnp-rboer-com:serviceId:Weather1 variable: eLastPollTSe was: 1670198550 now: 1670198610 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x7473c520>
50 12/04/22 19:03:30.102 luup_log:86: Multi Weather Station_debug: calling OpenWeather API with url = https://api.openweathermap.org/data/2.5/weather?lat=43.3862&lon=-79.8371&units=metric&lang=en&appid=NOTMYAPIKEY&exclude=hourly,daily,minutely <0x7473c520>
50 12/04/22 19:03:30.510 luup_log:86: Multi Weather Station_debug: {"coord":{"lon":-79.8371,"lat":43.3862},"weather":[{"id":801,"main":"Clouds","description":"few clouds","icon":"02n"}],"base":"stations","main":{"temp":-0.01,"feels_like":-0.01,"temp_min":-1.45,"temp_max":1.11,"pressure":993,"humidity":74},"visibility":10000,"wind":{"speed":0.89,"deg":84,"gust":3.58},"clouds":{"all":14},"dt":1670198490,"sys":{"type":2,"id":2007398,"country":"CA","sunrise":1670157328,"sunset":1670190244},"timezone":-18000,"id":5911592,"name":"Burlington","cod":200} <0x7473c520>
02 12/04/22 19:03:30.512 luup_log:86: Multi Weather Station_warning: No current data <0x7473c520>
50 12/04/22 19:03:30.512 luup_log:86: Multi Weather Station_debug: No forecast data configured <0x7473c520>
50 12/04/22 19:03:30.513 luup_log:86: Multi Weather Station_debug: calling OpenWeather API with url = https://api.openweathermap.org/data/2.5/air_pollution?lat=43.3862&lon=-79.8371&appid=NOTMYAPIKEY <0x7473c520>
50 12/04/22 19:03:31.109 luup_log:86: Multi Weather Station_debug: {"coord":{"lon":-79.8371,"lat":43.3862},"list":[{"main":{"aqi":1},"components":{"co":253.68,"no":0,"no2":12.34,"o3":57.22,"so2":5.72,"pm2_5":5.29,"pm10":6.74,"nh3":1.96},"dt":1670198610}]} <0x7473c520>
Looks like Iām getting data back, but the plugin doesnāt seem to be doing its thingā¦
Again - any tips are welcome! - Thanks!
Replying to myself againā¦ but I think Iām on to something:
Here is the onecall url:
(https://api.openweathermap.org/data/3.0/onecall?lat=33.44&lon=-94.04&exclude=hourly,daily&appid=)
Here is the response:
"lat": 39.31,
"lon": -74.5,
"timezone": "America/New_York",
"timezone_offset": -18000,
"current": {
"dt": 1646318698,
"sunrise": 1646306882,
"sunset": 1646347929,
"temp": 282.21,
"feels_like": 278.41,
"pressure": 1014,
"humidity": 65,
"dew_point": 275.99,
"uvi": 2.55,
"clouds": 40,
"visibility": 10000,
"wind_speed": 8.75,
"wind_deg": 360,
"wind_gust": 13.89,
"weather": [
"id": 802,
"main": "Clouds",
"description": "scattered clouds",
"icon": "03d"
"minutely": [
"dt": 1646318700,
"precipitation": 0
"hourly": [
"dt": 1646316000,
"temp": 281.94,
"feels_like": 278.49,
"pressure": 1014,
"humidity": 67,
"dew_point": 276.16,
"uvi": 1.49,
"clouds": 52,
"wind_speed": 7.16,
"wind_deg": 313,
"wind_gust": 10.71,
"weather": [
"id": 803,
"main": "Clouds",
"description": "broken clouds",
"icon": "04d"
"pop": 0.03
"daily": [
"dt": 1646326800,
"moonrise": 1646309880,
"moonset": 1646352120,
"moon_phase": 0.03,
"temp": {
"day": 281.63,
"min": 271.72,
"max": 282.21,
"night": 271.72,
"eve": 277.99,
"morn": 280.92
"feels_like": {
"day": 277.83,
"night": 264.72,
"eve": 273.35,
"morn": 277.66
"pressure": 1016,
"humidity": 55,
"dew_point": 273.12,
"wind_speed": 9.29,
"wind_deg": 3,
"wind_gust": 16.48,
"weather": [
"id": 500,
"main": "Rain",
"description": "light rain",
"icon": "10d"
"clouds": 49,
"pop": 0.25,
"rain": 0.11,
"uvi": 3.38
"alerts": [
"sender_name": "NWS Philadelphia - Mount Holly (New Jersey, Delaware, Southeastern Pennsylvania)",
"event": "Small Craft Advisory",
"start": 1646344800,
"end": 1646380800,
"description": "...SMALL CRAFT ADVISORY REMAINS IN EFFECT FROM 5 PM THIS\nAFTERNOON TO 3 AM EST FRIDAY...\n* WHAT...North winds 15 to 20 kt with gusts up to 25 kt and seas\n3 to 5 ft expected.\n* WHERE...Coastal waters from Little Egg Inlet to Great Egg\nInlet NJ out 20 nm, Coastal waters from Great Egg Inlet to\nCape May NJ out 20 nm and Coastal waters from Manasquan Inlet\nto Little Egg Inlet NJ out 20 nm.\n* WHEN...From 5 PM this afternoon to 3 AM EST Friday.\n* IMPACTS...Conditions will be hazardous to small craft.",
"tags": [
And if we look at the new method:
(https://api.openweathermap.org/data/2.5/weather?lat={lat}&lon={lon}&appid=)
With the response:
"coord": {
"lon": 10.99,
"lat": 44.34
"weather": [
"id": 501,
"main": "Rain",
"description": "moderate rain",
"icon": "10d"
"base": "stations",
"main": {
"temp": 298.48,
"feels_like": 298.74,
"temp_min": 297.56,
"temp_max": 300.05,
"pressure": 1015,
"humidity": 64,
"sea_level": 1015,
"grnd_level": 933
"wind": {
"speed": 0.62,
"deg": 349,
"gust": 1.18
"rain": {
"1h": 3.16
"clouds": {
"all": 100
"dt": 1661870592,
"sys": {
"type": 2,
"id": 2075663,
"country": "IT",
"sunrise": 1661834187,
"sunset": 1661882248
"timezone": 7200,
"id": 3163858,
"name": "Zocca",
"cod": 200
And from the log file in my previous post above:
ā¦which is quite correct, as the response data doesnāt have a current element.
Hi @retireditguy ,
thanks for your efforts and feedback on this. We are putting our best effort on these integrations and try to make it easy for you to use them without any code. So right now only temperature data is retrieved and its trivial to get all data from the API. Shortly we will update the service and present all data. Please stay tuned.
That sounds great, but coming from the world of Vera, it is all very confusing to me right now. (Hopefully āsoonā is not too far off.) After āinstallingā Ezlo Weather and OpenWeather via Ezlogic, I found that I had two instances of both EzloWeather and the OpenWeather token in Vera Mobile. After removing and reinstalling Vera Mobile, I also found the PAASAuthentication device. I have no idea what PAASAuthenticationās role is or why it was installed. I also found that a script was added called āGet City Tempā. There is no indication in the script how to input the desired city name variable. Hopefully once I have time to review āQuickstart - help.mios.comā I will start to understand what is going on and how to use these capabilities. The scene scripting in Ezlo is also differently confusing. Why do all Ezlo device scene scripts apparently start with a state change? Vera device scene scripts started by testing the current state and proceeded from there. Itās the difference between āIf x is onā versus āif x changes to onā.
Ā© 2024 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
