CURRENT VERSIONS
- Vera (all firmware releases, including the latest 1.7.5185/5186/5187): 3.11 (no current hotfixes)
- openLuup (requires 2020.04.14b or higher): 3.1 (no current hotfixes)
Installing the latest Reactor plugin is done from Github now. I no longer use the Vera App Marketplace to distribute and install updates.
To install:
- Go to the Reactor Github releases page
- Download the ZIP file for the current release.
- UnZIP the file contents to a folder on your local system.
- In the Vera UI, open Apps > Develop apps > Luup files
- Group-select the downloaded files (not the ZIP file) and drag them together to the Upload button in the UI.
- Wait until the upload finishes and your Vera has reloaded.
- Confirm the version number now running in any ReactorSensor (Tools tab, way down in the footer) or the Reactor master device (About tab).
REVISION HISTORY
Please refer to the CHANGELOG.md file in the Github repository for full release notes.
