Correct me if I understand this wrong- if I buy one of these Atom things, and install it in my home where I have Vera Plus running, there no way interconnect the two, in a way make Atom will run Vera scenes, use Vera plugins, and run the Lua code?..
In other words, at present the Atom will not extend my Vera, and my Vera will not be able to use any of the capabilities of Atom- right out of the box, that is?
You are correct. I have an Atom sitting in a drawer from the beta test. I device can either be paired with the Vera Plus or the Atom, but not both. If you have a Vera Plus you won’t find any use for the Atom. I didn’t spend much time playing with the Atom as the Atom wasn’t compatible with Google Home and having an Atom linked to the account would cause Google Home to no longer work on my Vera Plus. I put it in the drawer at that point as the Atom seemed to serve no purpose that I could see. I would have assumed that would have been fixed by now, except that yesterday an announcement was made saying Atom now works with Alexa. Since Vera had Alexa long before it had Google, and since I haven’t heard anything announced about Google, I’d assume that still doesn’t work.
The Atom really isn’t a hub, think of it more as a bridge between a z-wave (and possibily Zigbee - I don’t remember for sure if it had that or not) mesh and a wifi connection to connect to the internet. Nothing runs on the Atom, it’s all cloud based. It has much more in common with simple, cheap wifi plugs, etc. connected via a company’s cloud based app than it does to your Vera Plus. Honestly except for the longer battery life for things like locks and door sensors, the Atom offers no advantages over say TP-Link’s Kasa line, or something similar. With either that line or the Atom you’re setting up very basic scenes through an app and relying on their servers (and you’re internet connection being up and working) for anything to happen.
The PlugHub is just a single outlet z-wave plug with an Atom built in. It would work with the Vera Plus, but just like any other z-wave plug would. You won’t gain anything going with the PlugHub verses any of the many other options. I’m not sure what brands you’ve used and liked; but there are several I’ve used and been quite happy with that were less than the $40 the PlugHub costs. You can find some nice two outlet plugs on Amazon for about $30. If you prefer Zigbee devices you can get those for less than $20. (Your Plus will work with Zigbee, but I double checked and the Atom is z-wave only).
Welcome to the forums @MCakan. Just curious if I’m reading the tea leaves correctly - is Ezlo-Cast a piece of this puzzle?
Support of Ezlo-Cast.
All the nodes in the z-wave network receive the payload of Ezlo-Cast message at the same time. Ezlo-Cast frames are transmitted to a number of nodes ranging from 1 to 232 nodes at the same time. The frame may carry more then one destination address. It is making control of devices easy and fast. The same payload can be delivered to selected nodes only.
Thanks for the clarification. Sounds like Ezlo-cast is an Ezlo branding of “broadcast/multicast” for zwave. I incorrectly inferred that the branding meant proprietary extensions that may be used for other purposes. It is nice to see investments and progress in core zwave fabric optimization and stability.
So, I bought an ATOM to migrate the last few of my Zwave devices off a Vera Lite. Am I correct that I can still run similar scenes on my VeraMobile app ?
In fact, I have not been able to get the ATOM operational as I am stuck with a “Connection Lost” message after I manage to connect my (IOS based) phone to its Wifi and then return to the VeraMobile App… tried to network reset it, factory reset etc… but no luck…
Any suggestions ? (I am one foot away from the hub, the router etc…
Made progress (the Aeotec Power switch migrated well). But the Aeotec Home Energy meter (ZW095) nor the Thermostat (CT100) appear not to be recognized by the Atom… (they got unpaired from the Vera Lite allright), then blink nicely when trying to pair them with the Atom (which is less the 3 ft away) but several retries later, no pairing established…
Thanks for these pointers. Both devices are listed as supported (ZW095 as well as CT100) but the Atom does not appear to find them. I tried at least 10 times, having the Atom less than 3 ft away, but no luck. I had to reconnect them to the Vera Lite (which I am trying to phase out)
I had a quick look in the Mios app, it appears both of these Z-Wave devices are searchable and in the Add Devices wizard.
CT100 Thermostat
ZW095
When you tried to pair them to the Atom, if they don’t pair initially the app should then ask you to try un-pairing / excluding them first then it asks you to try pairing them again. Did you see that happening ?
Also did you exclude them from your VeraLite first before attempting to pair them to the Atom ?
