Appears the flicking of the files is because I had previously added my own custom icon image to one of them when the “Tile Settings” were there. Those settings have been removed since.
I don’t get flickering on another dashboard where I didnt add any custom icon images, so seems to be related to that.
A new Dashboard created in the standalone Ezlo Dashboard Configurator app does then not appear for selection for use in the Mios app.
Also please quickly fix the colour picker in the web app and the RGB sliders in the Ezlo Dashboard Configurator app. Its virtually impossible to select the exact colour / codes you want to use for tiles.
EDIT:
If you do it the other way round, create the new dashboard page in the Mios app then that new page does appear in the Ezlo Dashboard Configurator app.
The MiOS app is filtering the dashboards by controller.
You will be able to see and interact only with the dashboards assigned to the controller you are connected to.
Please check if this is the use case and let me know if is not.
Thank you,
Adina
Before the Mios app was even released, I created 3 dashboard pages in the standalone Ezlo Dashboard Configurator app.
Then later in the Mios app I could see those 3 dashboard pages I had previously created.
Now I created a 4th dashboard page in the standalone Ezlo Dashboard Configurator app, however this new dashboard does not appear in the Mios app.
It does appear OK in the website based version however.
If you do it the other way round, create the new dashboard page in the Mios app, then that new page does appear in the Ezlo Dashboard Configurator app.
As for controllers, I am using my Vera Plus in the Mios app.
I just switched to my Atom in the Mios app and the 3 original dashboard pages I created previously in the Ezlo Dashboard Configurator app are being shown in the dashboard settings.
But the new 4th dashboard page is not being shown in the Mios app for either the Atom or the Vera Plus.
Hello guys,
During the investigation I made with @cw-kid I found an issue regarding the way dashboards are saved from stand alone configurator application.
Please use the tool that is available inside the MiOS app for now.
I will keep you updated.
Thank you
update on how MIOS app is performing:
(Vera Plus, Android on S8, Alexa)
When connected to VP controller, can add dashboards with devices and scenes, but can’t access Alexa , Ezlo VOI option does not appear. Original Vera Mobile dashboard still exists and is functional.
When connected to Cloud controller, can only add 1 dashboard in the app but can add others via web. Dashboard Pro in dashboard settings does not appear.
Also when connected to Cloud, Ezlo VOI option exists and does connect to Alexa but when chatting with Alexa get “controller-abstracts-everywhere were not found” error message. (Note: using Sonos One as interface to Alexa).
Otherwise, progress is steady, which is good.
The Dashboard page does not refresh or update itself.
When I turned on the lamp the tile remains blue and 0%. I had to leave the dashboard page and go to another area of the app and then go back in to the dashboard page for the tile to then change to yellow and show the correct percentage.
But now setting them to different shades of grey the tile doesn’t show these grey colours, it’s just transparent as you can see in the above screenshot.
FEATURE REQUEST
Also please add a setting so we can properly make tiles transparent when off and I will set a tile colour for when on.
Also can the tile icons be made bigger in size, can hardly see them.
This is taken from the website configurator, its the same in the standalone Ezlo dashboard configurator app.
Also you cannot seem to edit existing dashboards or tiles in the Mios app currently.
The default icon shown in the configurator is not the same icon as that is displayed in the mios app for this tile, as you can see in the above screen shots.
Also No upload button to add your own image icon yet.
Can someone please explain why clicking any of those buttons doesn’t do anything? I’ve clicked them in various spots, single- and double-clicked, nada. I thought the whole purpose was to turn things on/off.
I don’t recall anyone stating that the beta Dashboards are supposed to non-functional, but perhaps I expected too much?
The website version and the standalone Ezlo Dashboard Configurator app are not functional. They can only be currently used for creating your dashboards.
They are functional somewhat in the Mios app.
I expect that the website version will become functional at some point.
Can you see the dashboard you created on the website in the Mios app in Settings - Dashboard Settings?
I suspect not as there is a bug where they don’t appear in the Mios app anymore, they did initially for myself but no longer for newly created dashboard pages.
You can create a new dashboard directly in the Mios app instead for now. But you will likely need to use the other tools to modify them, as you can’t seem to edit existing dashboard pages and tiles in the Mios app.
