No, the only other lock at my disposal is my front door deadbolt, paired with my VeraPlus, and it’s too much trouble to use that one for testing.
Excellent. I’ll stand by.
Wish I could answer you, but currently the Vera Mobile app won’t let me into any of my Controllers. I’ve restarted the app a number of times, but tapping any Location results in the following screen, which never resolves:
I’ll try everything again tomorrow when I have more time and patience.
UPDATE: Was again able to gain access to controllers by logging out of app then logging back in.
UPDATE 2: YES, I received the expected notification after running the Scene manually. The email subject is “Scene Finished” and body states “Scene Shed Lock Alert from Big Shed finished.” Very basic and I’d have opted for clearer language.
QUESTIONS:
What do all the options mean in the screenshot I posted above?
How can I make this scene notification run automatically when the lock changes state?
Unsecured - doorlock is open
Unsecured with timeout - doorlock is open and event will be generated with delay which you setup
Unsecured from inside - doorlock is open from inside
Unsecured from inside with timeout - doorlock is open from inside and event will be generated with delay which you setup
Unsecured from outside - doorlock is open from outside
Unsecured from outside with timeout - doorlock is open from outside and event will be generated with delay which you setup
Secured - doorlock is closed
Not all doorlock supporting Unsecured from insode/outside
It should work from the scene you created, rechecking it and will back with the answer.
The Ezlo Plus finally arrived being on the road since 15th of May
Adding it as a new controller went well although I had to add in manually since it is on a different sub-net than my phone. Added a Fibaro Wall Plug and it went well, very fast.
Trying to add a custom dashboard it says “No devices have been detected” although I can see the plug in the device-list. It works sometimes but sometimes not. It seems that all of the Tiles needs to have a device otherwise you can not save the dashboard or? In creating a scene I can not see sunset/sunrise condition. Is that not implemented yet? Forget It I found it
In the Web-interface it states that the controller is “offline” but in the Mios app it is “online”. I understand that no web interface is implemented yet but the condition should be the same or?
Testing continues …
In the Vera Mobile app I added a new “Vera Edge” controller as per the Beta Test Guide, I tried to scan the “barcode” which didn’t seem to work so I manually entered the units Serial Number and MAC address.
The unit was then added to the Vera Mobile app. In the Unit settings the Time Zone / Countries list is still not organised in order.
Also for some reason I cannot name the unit “Ezlo-Plus” it says invalid name and it does not llike the dash. Please fix this. My Vera units are called “Vera-Edge” and “Vera-Plus”.
I can login to the console with Putty the root password is on the sticker on the back of the unit.
Its OpenWRT still, I thought they were moving away from using OpenWRT but seems not.
I was able to assign a static IP of my choosing on my router and once I rebooted the Ezlo Plus from the Linux console, it now pings and replies to the IP address I gave it.
I can also connect to the unit using WinSCP and view the file structure.
Still no answer about the status of the enclosures? Have the enclosures been sent out? Was there an email notification that I’ve missed? And what about the assembly manual?
This is still an issue Unable to disable scenes
I’ve narrowed it down to Ezlo firmware as it’s working as intended when connected to my Vera using either iOS beta apps.
My Ezlo Plus unit also arrived here in the U.S. with an EU plug, which was unexpected.
FEEDBACK
Yesterday, I twice manually operated the Schlage BE369 deadbolt that I have paired with the e-Plus, expecting an “OR” Scene to run in response to both the “Unsecure” and “Secure” transitions.
However, the Scene did not run immediately. Instead, it ran approximately 12 and 14 hours later, whereupon I received the corresponding email notifications. Definitely not expected behavior!
I used the Generic Zigbee device option, it seems to detect the device and changes to say “Pairing your device please wait” but it never gets past this stage.
I would also like to know. Is it the H2 chip that is the processor? It seems it would be the best size fit for the thermal pad that came with the heatsink
Got mine the other day. I found it interesting that the instructions say to pug it in to a 2 amp power adapter, but the US adapter that came with it is only a 1 amp adapter. Presumably this is just a beta issue, and a better adapter would be included with the final product? The EU adapter that also came with it could do 2+ amps, it’s only the US adapter that is 1 amp limited.
Regardless, I was able to get it powered up and added to the account without issue following the directions in the e-mail. Obviously the “normal” methods of wireless setup or wired and scanning a barcode didn’t work, but that was expected at this point.
Adding/deleting rooms was fine. I would say that adding a room is fast enough that the message about the new room showing up momentarily is probably un-needed, as the new room shows up as quickly as said message does.
Ezlo VOI with my alexa is not working, although I’m not sure this is Ezlo Plus specific, as I get the same behavior on my Atom V2 at this point. Specifically, I get a message about having un-synced my Amazon Alexa account.
Found an issue, with trying to either update or add a new trigger to a scene.
Scenario - turn off plug adaptor:
Create new scene - choose the trigger based on a time, action = device action - turn off plug adaptor, save the trigger. At this point, the save happens.
Edit scene, change the time of the trigger, and follow the train to the end of the line, click to save change. Receive message “failed to save scene”
Light in scene, triggered by Voi is turn on and of continually(every minute or so for last 20minutes). The scene is will not fire manually. This scene was working until the issue with VOI after last firmware update. The scene has not been working for days, now it randomaly fires.
Thanks, I thought that would be the case, but so used to having to approve firmware updates, having waited for other users to have tested, and offered fedback on any changes.
