Qubino DC Flush Shutter - ZMNHOD1 (EU) doesn’t pair correctly with the Ezlo Plus.
I believe ZMNHOD3 is the US version of the same device.
Just unpaired the module from the Vera Plus and paired it to the Ezlo Plus.
Its done something very strange and added it as five devices not two, as I have the temp probe connected also.
I have 3x Window Covering devices named:
Flush Shutter DC
Flush Shutter DC 1
Flush Shutter DC 2
And I have 2x temp devices named:
Temperature Sensor 1
Temperature Sensor 2
If I press the Close button on the “Flush Shutter DC” device the blind starts to move down.
“Flush Shutter DC” device is showing at 100% the other two devices are showing at 0%
If on the “Flush Shutter DC” in the Vera mobile app I go to Z-Wave settings it says status Synchronized what ever that means? However it does not list any parameters at all that it may have detected.
I can’t seem to add any parameters myself also. If I press the Reset button on this page nothing seems to happen. Also if I “Rediscover” device it still doesn’t list its current parameter values or allow me to add any.
Bug Tracker Report:
https://jira.mios.com/servicedesk/customer/portal/72/ECS-431
Android app and Ezlo Plus versions
Also it says relay connected shouldn’t that say local?
Also on the Vera Plus when you add a new device and search for “Qubino” there are various device setup wizards including one of this DC Shutter module.
However on the Ezlo Plus when you do the same there are no device setup wizards listed.
I have seen this with other Z-Wave devices also. Is Ezlo moving away from dedicated device setup wizards ?
I’ve unpaired the module from the Ezlo Plus and paired it back on to the Vera Plus and that also has various extra devices, I must have hidden these extra devices from the UI7 web GUI and forget it did that after pairing.
So it doesn’t pair correctly on the Vera Plus either. “Lounge Blind” is the parent device.
