@goker @oleh @melih
My Ezlo Atom finally arrived today !
Setup wizard seemed to go OK but I cannot select the Ezlo Atom controller in the Vera app, I get an error and it doesn’t connect.
I assume this message was referring to the Atom’s own WIFI hotspot not having an Internet connection, I just clicked Connect Anyway.
The Atom was showing as offline and red for several minutes initially.
Eventually it become online and green. however when I click on it, I see this error message.
I can ping the Ezlo Atom device OK from my laptop and router and it replies. The blue light on the Atom is flashing on and off, not sure if that is normal ?
I tried unplugging the Atom device from the power and back in again but it made no difference.
Tried disconnecting the WIFI on my phone and reconnecting.
Tried closing the Vera mobile app and reopening. The app is version 7.40.492.
Phone is Android running version 9 Pie.
I then tried clearing the Vera Mobile apps Cache.
I then tried clearing the Vera Mobile apps Data and logged back in to the app.
On “Select Location” which should probably say “Select Controller” my Vera Plus and Vera Edge were showing as online however the Atom was red again and showing as offline.
Blue light on the Atom still flashing on and off.
At this stage I can still ping the Atom OK from my laptop and also from my router.
I had a quick look at the Get Vera gateway login page on my laptop, the Atom is also showing as offline on there as well.
So I waited for 10 minutes and its still offline, I was refreshing the Vera app page “Select Location” several times also.
I then unplugged the Atom for a second time and back in again. Ensure I could still ping the Atom device OK.
Atom still showing as offline.
Tried closing the Vera mobile app and opening again, still offline.
I then restarted my phone, opened the Vera Mobile app again and the Atom is still red and offline.
I then rebooted my router but its still the same the Atom is just showing as offline now all the time. I was unable to ping the Atom after the router reboot. Seems the Atom did not automatically connect back up to my WIFI.
So I unplugged the Atom for a third time and back in again. However I now still cannot ping the Atom.
Its still flashing blue on / off for 3 seconds.
After quite a few minutes I can now ping the Atom once again OK. However the thing is still showing as red and offline.
Extremely disappointing experience after waiting so long to receive this Atom sample in the post. I think end users would really struggle at the moment with these setup problems.
At this point I was getting hungry and gave up for now.
