Yes, I have tried it and it has no effect.
Warren
Warren
I guess vera does not impletement the stop command.
I use z-wave sniffer, vera doesn’t send any command when click “stop”.
tested in firmware 1.1.1340
Has there been any advancement with this? has it been determined if the issue lays with the vera or the aeon labs motor controllers?
I am using one to control a projector screen and would like to be able to set the screen for different aspect ratios.
Yes the stop function now works with UI5.
So I still need to change the device from dimmable light to window covering?
Yes, I have mentioned how at the start of this thread and it has worked for me every time.
OK I changed the device type as shown at the start of this thread. I’m still on UI4 so STOP doesn’t work yet but I also use these controllers to control shutters and I have noticed that although DOWN shuts the shutter and UP raises it, OPEN conversely shuts the shutter and CLOSE raises it. Is there a way to reverse the functions of OPEN and CLOSE?
you could ask aeon labs for the parameters on the device and pass these to MCV so they can have a look at it and make it properly work ![]()
also there is a option to exchange the power wire to the motor which reverses it.
or change it in the xml file.
what one can do is make a modified one.
just copy and rename the blinds xml D_WindowCovering1.xml and the device type in the xml itself. this way you could add your own device support for it and add additional functions.
I tried to think of a way to change the wiring…but I’m quite certain that if I swap the motor wires then that will just reverse the UP and DOWN functions…I was hoping that there was maybe a variable I could enter in the device settings to swap the way OPEN and CLOSE relate to UP and DOWN.
Sent from my GT-P1000 using Tapatalk 2
[quote=“baxy_AU, post:49, topic:167879”]I tried to think of a way to change the wiring…but I’m quite certain that if I swap the motor wires then that will just reverse the UP and DOWN functions…I was hoping that there was maybe a variable I could enter in the device settings to swap the way OPEN and CLOSE relate to UP and DOWN.
Sent from my GT-P1000 using Tapatalk 2[/quote]
What is the best way to try to get MCV to fix this issue?
