Do you know if it is possible to set up the box using a computer?
LimitlessLED claim to have a PC program to do this on their site: [url=http://www.limitlessled.com/dev/]http://www.limitlessled.com/dev/[/url] but I have not been able to locate the link.
I have tried from 2 ios devices, on 2 different wifi networks
Are your networks 801.11n? It is possible the V4 bridge will not connect to a, b or g networks.
I can’t seem to get this to work. I have a new wifi Bridge, I believe it is v4. I have used the app to set it up to work through my wifi and linked Lights so phone app is controlling Lights fine.
Installed add on and entered ip and mac address. But there is no variable under advanced for group.
[quote=“gdeboos, post:105, topic:185697”]I can’t seem to get this to work. I have a new wifi Bridge, I believe it is v4. I have used the app to set it up to work through my wifi and linked Lights so phone app is controlling Lights fine.
Any ideas? I have the rgb controllers and add on.[/quote]
With the RGB lamps and MiLightRGB pugin (as opposed to the RGBW type) the Wifi Bridge only supports one group so there is no need for the Group variable.
Did you set your Wifi Router to fix the IP address of the Bridge?
[quote=“RexBeckett, post:106, topic:185697”]With the RGB lamps and MiLightRGB pugin (as opposed to the RGBW type) the Wifi Bridge only supports one group so there is no need for the Group variable.
Did you set your Wifi Router to fix the IP address of the Bridge?[/quote]
RexBeckett thanks for your help!
My RGB controllers are assigned to different zones/groups on both the physical and phone app remote, not sure if this makes a difference?
Yes the bridge is on a reserved ip address, and have double checked it is same as advanced tab settings.
Still no luck
Sorry I am at work so cant check the actual device but here is a link to what I have.
I have 1 wifi bridge, x2 of the RGB contoller boxes, and x1 remote control
That looks like an RGB+W controller but without the white channel. Try using the MiLightRGBW plugin. I have not seen any information on this controller so it is possible some of the functions will not work correctly.
That did it. ;D
And as far as I can see all functions are working including white. Thank you very much!
Have checked and definitely says RGB on controller boxes, but no matter all sorted
I don’t see new firmware posted on www.limitlessled.com/dev - am I missing it? If not, what’s the ETA?[/quote]
Or Can you tell us how the MiLight app does it programmatically. Web disabled ok and if you don’t have a smart phone, Link it with open security? I have tried to send AT+ commands though the IP UDP not working.
Please help
Never mind I managed to connect and put into command mode. Next to reload web server,put the dashboard back in my MiLight Wi-Fi bridge. I want a dashboard. Thank you!
