WiDom DRY700 parameter configuration error
Hi, is it possible to have support for this device? Impossible to use parameter configuration.
I have some of these device to open main door and water heater and boiler
WiDom DRY700
https://products.z-wavealliance.org/products/4615?selectedFrequencyId=1
My controller:
Ezlo Plus
2.0.48.2397.3
Firmware version
Screenshot 2023-12-03 191945
Screenshot 2023-12-03 180510
Hello lord55,
Thank you for bringing this to our attention. Please know that device integration has already been issued by our team, it has to be evaluated and if accepted it will be implemented with ezlo. This may take a while and usually, the changes are seen on firmware releases, You can track progress from here Service Desk
To check for any news, they will most likely be posted on this Community Forum, I suggest you keep an eye in the official thread to request integrations as well: Tell us which integrations you want us to make for the EZLO PLATFORM please
Hi was this ever fixed ?
Hi cw-kid!
No, It is still not resolved and they are also important device for the house because with them I controll the main door open/close and the HVAC heater. I hope there is some progress on the last 700 and 800
compability series also because I want to introduce some mmwave device too in the next future.
I saw your old ticket whilst I was looking for something. I asked the Device Integration team to look at it again. Fingers crossed.
Hello @lord55 ,
Which setting or parameter did you attempt to update?
Hi, the parameter that most I need to setup about Widom W-DRY700 is:
Timer_Setup
and also I notice that, maybe after the last update, I have lost a Fibaro device FGS-224 from device list, how is it possible that a device has an auto remove?
Thanks in advance!
Hi, looking at the progress on Smart Dry Contact Switch 7 and according with the manual on parameter 30, it is asked to put a number as sum of the event values. The events values are eight and they not corrispond to the actual settings.
Example: how can I insert sum 33?= 1 click + network
Timer management
It allows you to activate an ON and OFF timer independently. To activate the timers you need to:
  1. Define which event will start the timer (Parameter 30)
  2. To set the Off timer define the time with parameter 31
  3. To set the On timer define the time with parameter 32
Parameter 30 TIMER_SETUP - Value Description:
0 disabled
1 1 click
2 2 clicks
4 3 clicks
8 Hold down
16 Up
32 Network (status change trigger by gateway or other devices in the Z-Wave™ network)
64 System (based on the startup status, or other timer event)
If more than 1 event are supported, the value for the configuration parameter is the sum of the event values.
For example:
1 click and 2 clicks → Parameter value must be 1 + 2 =3
thanks in advance
Hello @lord55,
Thank you for your message and follow-up.
We have forwarded your question to the developers, and will let you know as soon as we receive a response.
