i would like to start a project using Vera edge buit i don’t know if it could be posible. The idea is:
2 video camaras activated if someone is detected. I would like to record images and access in remote. Maybe using the Vera app.
2 door sensors (pincipal and garaje door)
Several switchs to turn on electric engines like pool, irrigation, etc
I have review the community forim and i can’t find information about security integration, My doubts are:
Which camaras is suitable to integrate with Vera Edge? I would like find camara with movement sensor integrated
Is Vera edge a useful controler to create these escenes?
Is it possible to record videos images and access in remote?
Thanks a lot for your help.
Kind regards
cw-kid
December 8, 2020, 12:38am
2
Vera have their own range of IP cameras that integrate with the Vera controllers.
For a proper CCTV system however, you might be better looking at a dedicated NVR (network video recorder) and IP POE cameras.
Hikvision or Dahua are two leading manufacturers.
cw-kid
February 24, 2022, 11:11pm
3
A staff member edited this post to fix the link I think and that bumped up this old thread.
While I’m here Ezlo have some NVR software called Vidoo.
melih
February 25, 2022, 12:05am
4
to detect “someone” …you need “object detection”.
So that you can detect a “person”…and perhaps a “Zone” detection…
so that you can detect a “person” in a “Zone”…
You can do all this with https://www.ezvidoo.com/ that is integrated into Ezlogic.
You can write a MeshBot where if a person is detected in a zone etc, do some action…
Here is a post I made in the past showing a MeshBot i created (of course instead of notification you can choose an action like recording or some other action)
[image]
I am excited because this is an important milestone for https://www.ezvidoo.com/
I was able to create a Notification Meshbot (that alerts me both thru push messages to my Iphone as well as email) to do the following:
Detect an Object : a Person
in a Camera
and In a Zone within that camera…
So first you select the type of “detection” you want…I selected “Object”
[image]
then you select the category of object…I selected person
[image]
then you select a specific camera if you wish…
