[quote=“tiaanv, post:18, topic:184813”]Ok. After putting some unrelated info together I have managed to bridge two Vera edge units together… and yes… it works!
Based on info in this thread we could establish that the main issue is that the Vera uses the “LAN” interface to discover other Vera devices via uPnP. The only issue is that the LAN interface IP addresses for all Vera edge devices are statically set at the factory to 192.168.81.1. In the older devices you could change this… On the new Vera Edge you can’t… Well, maybe you can!
SO I started digging around an came upon another unrelated post in a random thread about how to do some weird stuff with the wireless on a Vera 3… I put on and one together, and presto…
The Steps:
1. You need to SSH into your vera (
either of them will suffice. Only do this on ONE of them), using putty or something similar. You’ll also need your vera’s root password, or temporarily enable remote support, and use those details. there is enough info available on this… Google is your friend…
2. You need to run a couple of commands:
[ul][li]uci set network.lan.ifaddr=“192.168.81.2” (this sets the LAN interface’s IP address)[/li]
[li]uci commit (this saves the changed settings)[/li]
[li]cat /etc/config/network (just to review that you changed the setting correctly…)[/li]
[li]ifconfig eth0.1 down (this will “down” the LAN interface. We do this to re-load the settings in a moment)[/li]
[li]rm /var/state/network (this clears the network cached settings)[/li]
[li]/etc/init.d/network restart (restart the network)[/li][/ul]
3. After doing the above, You need to restart BOTH your Veras so that the uPnP service restarts it’s discovery.
That’s it… Fully functioning Bridging…!!!
Warning!!! I have NO IDEA if this will leave anything broken… So far, for me, it’s working perfectly, but don’t blame me if this has any negative after effects… at OWN Risk![/quote]
I used the above procedure, but the IP would not change. It did give me a another line that had the right IP, but this IP did not take effect. I had no idea how my VeraEdge had the ip of 192.168.12.24 and while my VeraLite had 192.168.81.1. The VeraEdge was visible on the VeraLite unp, but the VeraEdge did not show the VeraLite. After many attempts using the above procedure, I used SCP and using the terminal mode, I edited etc/config/network file and made the change to the IP 192.168.12.24 to show 192.168.81.2. After, I rebooted, the Veralite was visible on the VeraEdge and all devices made to trip to the VeraEdge. I later deleted the second IP line and everything works just great. It is my feeling that just editing the etc/config/network file is all that is needed to change the IP to get the VeraEdge to bridge to the Veralite.
config interface ‘lan’
option ifname ‘eth0.1’
option type ‘bridge’
option proto ‘static’
option netmask ‘255.255.255.0’
option ip6assign ‘60’
option macaddr ‘z4:41:22:fc:b4:ab’
option ipaddr ‘192.168.12.24’ 1.
option ifaddr ‘192.168.81.2’ 2.
