Has anyone tested the GE alarm plugin?
Thanks!
Thanks!
[quote=“BOFH, post:1, topic:182371”]DLNA Not Working
Sonos Partly working See post #7 below[/quote]
I just made an attempt to fix UI issues relative to UI6/UI7 for these 2 plugins.
Let me know on the following topics if it is better with these changes:
http://forum.micasaverde.com/index.php/topic,26685.0.html for Sonos
http://forum.micasaverde.com/index.php/topic,26690.0.html for DLNA
Shameless bump. ;D
Vera Alerts Plugin Works (Including it’s Twilio interface)
The only thing not working is sending Photos/Images to Vera Alerts Android Phone.
Updated. Thanks Richard. Slowly the list is greening up. 8)
Any news on advanced settings yet? I really cannot try this new update without it. I like the new simple UI, but without advanced settings its hard to tweak scenes in complicated scenarios.
Javelin
The working plugin list continues to improve. But I still can’t find a way to create multiple appearances of the same item, PLEG, Virtual Switch, Blue Iris Camera, etc. Is this hidden somewhere I haven’t found or it it pending the next release?
Once they get a functional release what’s the money on simply being able to upgrade without having to go back to square one and reinstalling and recreating everything (PLEGs, notifications, especially )
[quote=“BOFH, post:1, topic:182371”]DLNA Not Working Developer posting at http://forum.micasaverde.com/index.php/topic,26690.0.html
Sonos Mostly working See http://forum.micasaverde.com/index.php/topic,26685.0.html[/quote]
Just to let you know that it makes no sense in my point of view to have a different status for these two plugins.
I don’t see the Variable Container plugin listed while this plugin is probably used by almost everybody.
It uses a JavaScript tab, so …
[quote=“clippermiami, post:70, topic:182371”]The working plugin list continues to improve. But I still can’t find a way to create multiple appearances of the same item, PLEG, Virtual Switch, Blue Iris Camera, etc. Is this hidden somewhere I haven’t found or it it pending the next release?
Once they get a functional release what’s the money on simply being able to upgrade without having to go back to square one and reinstalling and recreating everything (PLEGs, notifications, especially )[/quote]
i have already covered multiple instances of same app earlier in this thread
for now it must be done manually
create new device and copy all the device types from the existing device
ie. device filename implementatation filename etc…
I guess I missed it.
Deleted
[quote=“lolodomo, post:71, topic:182371”][quote=“BOFH, post:1, topic:182371”]DLNA Not Working Developer posting at http://forum.micasaverde.com/index.php/topic,26690.0.html
Just to let you know that it makes no sense in my point of view to have a different status for these two plugins.[/quote]
So are both working, mostly working, partly working or not working? I’m depending on contributions from people who have tested these and have been unable (but I may have missed a post) to find someone posting other than ‘not working’ for the DLNA plugin.
I’ve been tidying up my plugins so that they function (mostly) on UI7.
Caddx NX-8/NX-584 Alarm (SVN @80): Once you’ve arranged the serial connection*, works correctly (but icons are broken).
CurrentCost EnviR energy monitor (SVN @31): Once you’ve arranged the serial connection*, works correctly.
Combination Switch (SVN @20): works correctly (but icons are broken). It’s tedious to add a second one in 1.7.318 because the Add Another button is gone.
Countdown Timer (Version 7.0 submitted to apps.mios.com): works correctly (but icons are broken). It’s tedious to add a second one in 1.7.318 because the Add Another button is gone.
UPnP Event Proxy: already worked.
Heliotrope: already worked but you may have to re-select your location (mine was emptied in the update).
Belkin WeMo: Needs a maintainer. I no longer have any WeMo devices.
Power Arithmetic: already worked.
I got slightly better behaviour in the UI7 web interface with this modified D_HueLamp1.json file. The changes were:
Adding to the first tab:
"top_navigation_tab": 1,
(see: http://forum.micasaverde.com/index.php/topic,26649.msg189644.html#msg189644)
Adding to the preset buttons’ Display section to make them clickable:
"Service": "urn:intvelt-com:serviceId:HueColors1",
(see: http://forum.micasaverde.com/index.php/topic,26649.msg190623.html#msg190623)
[quote=“BOFH, post:76, topic:182371”][quote=“lolodomo, post:71, topic:182371”][quote=“BOFH, post:1, topic:182371”]DLNA Not Working Developer posting at http://forum.micasaverde.com/index.php/topic,26690.0.html
So are both working, mostly working, partly working or not working? I’m depending on contributions from people who have tested these and have been unable (but I may have missed a post) to find someone posting other than ‘not working’ for the DLNA plugin.[/quote]
I am waiting for feedbacks after the last changes but mostly working should probably be more accurate.
Anyone know if concord alarm plugin is working?
