Using a cheap RS232 to Ethernet module
I’m a newbie here and haven’t yet purchased a MiCasaVerde device yet but I have a Powermax Pro alarm system and was wondering how to connect them together. I’ve been a member of the forum for a while but didn’t spot this subject area for some reason until now.
I was wondering if I could use a “cheap” device such as this one on ebay:
http://www.ebay.co.uk/itm/RS232-Serial-TTL-UART-TO-Ethernet-TCPIP-convert-adapter-Module-/281186328627?_trksid=p2054897.l4275
I think I would also need an RS232 Powermax module (approx ?30). Would they both fit inside the Powermax and get power from there as well. So I would only need an ethernet cable to the Powermax?
Would I then be able to connect the ethernet to my router and access it from a Vera Lite?
Thanks for any help
Yes, works well with a USR-TCP232-T. You won’t even need the Visonic RS232 module, as the PowerMax IP interface has the TX/RX signals on 3.3V which you can connect directly. See this post. I only still need to update the plugin to communicate directly via IP (now it always expects a USB device). I’m planning to do that in the first upcoming release.
Thanks for the quick response and you helping me out.
So all the Visonic RS232 device does is change the voltage levels with a MAX232 chip, charging so much money for it is scandalous.
I took your advice and I’ve just bought this from EBAY:
http://www.ebay.com/itm/New-Dual-serial-RS232-TTL-to-Ethernet-Converter-TCP-IP-Module-DHCP-WEB-3-3V-5V-/181205172624?pt=LH_DefaultDomain_0&hash=item2a30ab8190
It is the updated model to the hardware you identified, called a USR-TCP232-E
It is pin compatible with the USR-TCP232-T but has the capacity for dual RS232, has DLNA and a couple of other extras.
I know this is the obvious question but do you have timescales for the software update you are planning that includes IP?
Thanks again
It does a bit more, but that is the essence. Wouldn’t say it is scandalous, just normal business.
[quote=“smeghead, post:3, topic:177481”]I took your advice and I’ve just bought this from EBAY:
It is pin compatible with the USR-TCP232-T but has the capacity for dual RS232, has DLNA and a couple of other extras.[/quote]
I’ve ordered the same one from the same store yesterday, as I also want to test it out in one of the alarm panels. So let’s see who gets it first :).
I’ve currently shifted attention to developing another plugin, so once that this done I will look the PowerMax plugin code again. The code has already undergone some major changes (e.g. added the option to edit panel settings from the plugin, backup & restore of panel settings). Hence it will need quite some testing. So hopefully around the Christmas holidays.
I recieved my USR-TCP232-E today and it works well :D. You only need to add the following to the lua file to make it work (put this before the comment ‘-- Check serial port connection’):
-- Check if connected via IP local ip = luup.devices[pmPanelDev].ip if (ip ~= "") then local ipaddr, port = string.match(ip, "(.-):(.*)") debug("IP = " .. ipaddr .. ", port = " .. port) luup.io.open(pmPanelDev, ipaddr, tonumber(port)) end
hello
nlrb, could you please give the ebay vendor name ? (the link doesn’t work with me).
I bought that cable, I guess it’s the same: http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=400545942205&ssPageName=STRK:null:IT&_trksid=p3984.m1542.l2649#ht_3034wt_1397
On a POWERMASTER 30 model, so I have to use the IP connector ?
Is it the same pineout as the powermax pro PC/IP connector ?(drawing here http://www.domoticaforum.eu/viewtopic.php?f=68&t=7152)
If yes I then connect my RX cable to the Powermaster TX cable, TX->RX, and the GND
ANd the USB to the Vera
Am I right ?
Thanks!
You have a TTL->USB cable. What we’re discussing in this topic is TTL->Ethernet.
You have a PL2303 based TTL->USB. This should work, although I would recommend an FTDI based one.
You indeed need to connect RX->TX and TX->RX and GND. Pinout for a PowerMaster 30 is the same as the PC/IP on a PowerMax. A USB cable will get the power from the USB, so don’t connect the VCC to the PowerMax.
Hi nlrb,
First of all thanks again for all your help. I received my RS232/Ethernet gadget mid November but I’ve been really busy at work and there aren’t enough hours in the day to do home projects. Until, that is, the holidays times come along!
And now for my confession, I have recently set up an HP N54L server as I now use Plex (https://www.plex.tv/) for my media. I bought the server when it had the ?100 cashback so couldn’t really refuse, it made it less than ?95 delivered. I also bought a Sony GS7 (for ?74) and that was my Vera pot of money used up. So, for the foreseeable future I’ve been investigating other options.
I came across HomeGenie (http://www.generoso.info/homegenie/) and I’m looking to maybe create a plugin for that. What I have done so far (today) is to look at your Lua code and generate simple Java code that connects to the TCP Server and provides very simple interaction with the alarm, nothing like the comprehensive capability of your script but it shows that I can interact with the alarm.
What I’d like to do is to convert your Lua (the bits that do the alarm interaction) to Java or C# and contribute it to the HomeGenie project.
But I will not do that unless I get your OK. I would of course reference your hard work at deciphering the codes etc.
Thanks again
Hi smeghead,
The source code is available under GPL terms, so yes you can use it (taking the terms into consideration). HomeGenie looks interesting; maybe the excuse I was looking for to buy a Pi.
I already own a Visonic PowerMax Pro and just got a Veralite yesterday, I decided to get Veralite instead of Revolv because I saw this post. My powermax pro connect to home network via powerlin2. So, if I buy that RS232 to Ethernet adapter, do I still need to use my powerlink2?
No, you don’t need to (can’t use) the PowerLink2 when you use Vera.
Thanks for respond. I am pretty new to this forum so any helps are appreciated.
By using that adapter, still I be able to access my Visonic Powermax by using “My Visonic” app or I have to use MMS Vera app? I saw some user using USB to RS232 to connect Powermax to Vera, which one is the preferred method if I would like to be able to access my Powermax with my Visonic app or MMS Vera Plus be able to remote programming my Powermax from my PC?
You won’t be able to use the ‘My Visonic’ app, as that will need to communicate to a PowerLink module. I don’t know to what extend the MMS Vera app supports alarm panels, as I’m not on UI6. But you should be able to control the panel with the Vera app using scenes.
Just ordered USR-TCP232-E. It takes 3weeks to get here. Thanks
Hello,
I am going the same route to connect my Visonic PowerMax and bought the USR-TCP232-T module which works very well with an external +5V power supply. I am now wondering if I can power the module directly from the Visonic. Looking at the Visonic connector it seems to provide 3.75V or 3.0V (in my case, actual measurements give respectively 3.56V and 3.10V). The module specs indicate either 4.5-5.5 for VDD, which doesn’t seem to be available easily on the PowerMax board, or 3.3V for VCC with tolerance 3.15V-3.45V.
Question: is it safe to use the 3.75V to power the module through VCC ? I know the difference is not that big with the max tolerance (0.1 to 0.3V) but I would not like to burn stupidely my module (it took me almost four weeks to get it from China !). Has anyone some experience to that respect?
Thank you very much in advance.
thefrip
I am using the -E version in 5V mode connected to the 3.75V, which works fine. But just give it a try, you cannot break it.
[quote=“nlrb, post:5, topic:177481”]I recieved my USR-TCP232-E today and it works well :D. You only need to add the following to the lua file to make it work (put this before the comment ‘-- Check serial port connection’):
Hi nlrb!
I used to connect my Powermax to Veralite vis USB to rs232 adapter. Since I moved my powermax panel, It is not allow me to use USB/RS232 anymore. Now I try to connect by using this adapter. Do I need to uninstall my powermax from my vera then re-install with new code? how can I enter these code? could you describe more detail? Thanks[/quote]
That code is nowadays already part of the plugin by default. So no need to add any code.
But for somehow my router could not get IP from that adapter. I got this message “PowerMax : Please set an IP address and port or select the serial interface for the PowerMax” any help appreciated.
I just used a Wiznet 110SR to connect my monoprice multizone amp and it works very well.
