Hello @clawmd,
We kindly invite you to look for the model number of your door lock. You should be able to find it on the device (usually removing the battery cover,) the manual, or the box. You can also ask the manufacturer. Then, you can see our list of fully integrated Z-Wave devices here to make sure your device is listed. If the device is not listed, you can use our Community Feature and Bug Tracker tool to send an integration request. More information on this tool here.
Regards!
