Updates for EZLogic - 1.51.1 (Ezlo Hubs only)
Link: https://ezlogic.mios.com/
Previous: Updates for EZLogic - 1.50.1 (Ezlo Hubs only)
Reset password page.
We implemented Reset Password page. New password must meet requirements:
Then, it is necessary to re-enter it and confirm.
After you could go to login page and use your new password.
Note: Reset password email template is still Vera branded and contains getvera link. It works fine and will send you new password in the next email. The template will be updated soon. Untill that time if you are interested to try reset password page, you could copy path (as on the image) and open ezlogic.
Example: https://ezlogic.mios.com/#/passwordreset/confirm?user=2950622&code=.j4H5yVlrOV2~7
Fixes and Improvements:
  • Fixed IP Devices page, removed dependency to controller(s) loading state.
  • Fixed Variables and Expressions page for the case of switching between active controllers and incoming broadcasts.
  • Fixed Local Variable node in Local MeshBot.
  • Fixed “white screen” login issue for some accounts with missing customization data.
  • Fixed NOT operator in Local MeshBot.
  • Fixed number of devices on Plugins page.
Thanks!
Definitely fixed the problem with IP Devices page (stuck loading).
