UI7 Support?
Yes it works fine. If the error bothers you contact vera support. They logged in to my system and removed the flag. No error, works 100% and I’m on UI7. VERA EDGE on order.
I need to jump in on this thread. I just replaced a broken VeraLite with a new VeraEdge. In doing so I also had to switch from UI5 to UI7. I see everything in my devices as before (DSC Alarm Panel, Partition 1, and all 6 door/window sensors). But I can’t seem to arm the system at all. It just tells me Remote Arm Is Not Enabled. Also, my HomeWave app needs to be reconfigured in all this too. I have been able to set it all back up except for the alarm again. When I try to assign a device to that control there is no alarm to choose. So something is obviously not working right with the alarm integration in UI7 right now. Any suggestions or ideas? Maybe somebody could suggest what all of the various settings should be for Partition 1 and DSC Alarm Panel. And where do I put in my PIN for arming and disarming the alarm? Its been so long since I did this on UI5! And now it all looks different anyway!
I agree, it would be great if someone could post screenshots of what all the settings should be for the app in UI7. I too moved from UI5 to UI7 and DSC Alarm is the only thing I can’t seem to get working. When I try to arm, I get the message “remote arm is not enabled”. I have entered the IP, port, MAC, and set EnableRemoteArm to disarm. I’m not sure what I’m missing. Any help would be greatly appreciated.
I have the exact same issue as tooslo. Everything seems to be working with the DSC plugin, I can see all devices, I can arm the system, but I am unable to remotely disarm.
I am trying to arm and disarm from my yale door lock
Well, you’re farther along than I am. I can see all zones as well, but I can’t arm or disarm. However, I might have an answer for your issue. I have read that you must set the variable EnableRemoteArm to “disarm”, otherwise only arming is allowed.
Cant seem to find enableremotearm anywhere in the settings in UI 7
Hello everyone,
Did you ever resolve this issue with “Can’t detect device” ?
I recently installed a PC1616 and a EVL3, Vera 3 UI7. The plugin created 6 zones, the DSC alarm panel (which says cant detect device) and Partition1.
I put the IP-address on both panel and partition1 but it did not change a thing.
Any ideas?
/Mike
Seems that this plugin support forum is hit or miss. :-\
I can login via http to the EVL3’s webserver and this is what it looks like.
I also created an account with eyezon and established a link between EVL3 and eyezon.
I’ve seen some posts about replacing a few xml files or change a line inside an XML. There was a post about an indefinite loop which caused the error.
I hope that the developer of DSC plugin can take a look at this since it seem to be a common error with UI7.
This is the link I was talking about, but I’m not able to access the “trunk”
http://forum.micasaverde.com/index.php?topic=26484.15
