Trouble with Vera2: No ZWave dongle
It is strange. My Vera2 was worked fine and I did no any changes in last many weeks.
But today evening it stops managing scenece, when I enter it from computer it shows red box in top left with the message - No ZWave dongle.
I have USB flash drive used for logs and swap, I switched all off, I did a restart - nothing helps (
I’ve checked micasaverde.com/vera2 and it told me that I’m up to date with my firmware
Yes, I’ve submitted a support ticket but it will need days for response.
What is wrong? Dongle is integrated, what does it means that “no dongle”?
I’ve searched throuth forum but did not found a solution.
My Vera currently useless
I also just submitted a ticket. My Vera 2 just did the same thing. Error “No Zwave Dongle”
Which firmware do you have? My is 1.1.1350
Hi Guys, as you already know we don’t work over the week end so this is why the delay. I just send you both a reply asking for access codes. I can’t be sure what’s the problem until I get a chance to access the units. So send me the access codes and hopefully I’ll be able to fix this very soon.
not sure what the issue was but the tech support got me up and running monday morning.
For me too, but on Sunday I’ve got the same trouble again - No zwave dongle.
Becoming strange
it is that i found in log file:
ZWaveSerial::Send m_iFrameID 819 got a CAN – Dongle is in a bad state. Wait 1 second before continuing to let it try to recover.
For two weeks already my Vera is in useless state.
Micasaverde support is silent
In this two weeks a few days it works but like this - half a day is working, the rest is not
What is also strange for me - while Vera is not working (showning “No zwave dongle” or “Failed to start”) all my direct device to device associations are also not working.
Mios released a new firmware which they think should fix my problem but it was not.
I did an upgrade - same No zwave dongle message.
I did a few restarts with one power circle.
Now message about No zwave dongle diseapeared but by zwave network is 100% broken.
For example if I try to switch a light on it failes with transmit failes error code 2 message
Any chance for me to recover my home?
Most probably your Z-Wave Home ID changed, which means that you have to exclude and re-include your devices, but if you already have an ongoing tech support ticket, I would wait for their answer.
Thanks for reply. I will wait for reply from support.
My network contains about 40 devices, some of them it is hard to access.
It is strange to rebuild the full network
I’m having the same problem and I bought my vera only one week ago. I already made the report to the support (MiOS tech support #29137) and now i’m waiting for the solution.
My problem posted 29 oct, more than two weeks ago, Micasaverde not able to find a solution still
[quote=“axill, post:9, topic:169457”]Mios released a new firmware which they think should fix my problem but it was not.
Any chance for me to recover my home?[/quote]
I did an upgrade (1.1.1362) but still with the message “No Zwave dongle”
The support, just a few minutes ago, solved the problem, I don’t know what they did but for now is working.
my congratulations
my Vera still dead
MiCasaVerde support please reply to me.
You last reply on my issue was 11 Nov, problem not solved.
I’m having the same issue. What i can’t understand is, that support doesn’t post a solution or tell anybody what they’ve done. So all of us doesn’t need to start a support case… ??? ???
Currently my network is working time to time etc. unstable
What is strange - devices shich are working lists as Neighbors only id 1 (i think it is Vera intself)
no routes throuth other devices
heal do not helps
I’ve experienced a bad-bad support from Micasa. 3 weeks without solution, 3 weeks without any feedback to my messages and to my supporting tickets.
Micasa died?
