I’m still a little stuck as to the best and easiest way to use my Trane thermostat with Vera. As mentioned earlier in this thread, the thermostat allows me to toggle between “Energy Saving Mode” and normal “Run” mode schedules. Ideally, I’d be able to remotely switch between these two using Vera, but Vera only allows me to adjust setpoints and to turn the thermostat and/or fan on or off (or to Auto). Apparently there are some command codes that will allow this, but I still haven’t been able to find anything out about these. So, in the absence of this desired functionality, I have a question about my work-around.
At present, I leave my weekend home and put the thermostat into Energy Saving Mode. Before I go back to the house, I simply adjust the setpoint through Vera to ensure the A/C is turned on when I arrive, and then when I do arrive, I simply switch the thermostat into its normal “Run” schedule while I’m there. What I’d like to do, in situations where friends/family use my home, to avoid having to explain how to use the thermostat, is to control it all through Vera. So, if I leave the thermostat in its normal “Run” mode schedule, and I use Vera to change a setpoint, will it…
a) put the thermostat essentially into “Hold” mode at that setpoint? -or-
b) temporarily change the setpoint until the next schedule event in the thermostat program, and then simply revert back to its normal “Run” program?
And if the answer is a), can I bump the thermostat back into its normal “Run” mode/schedule if I use Vera to turn it off completely, and then turn it back on to “Auto?”
Hopefully what I’m trying to accomplish makes sense. I basically want to leverage the standard thermostat program features during normal operation (when I’m at the house), and only use Vera to change the setpoints when I leave (and hold them there), but be able to revert back to normal program mode remotely again.
As mentioned above, all this could ideally be solved with a Vera command to toggle between “Run” and “ESM”, so if anyone actually knows how to do that, I would appreciate hearing about it.
Thanks!
