Well that’s great that a small fraction of the functionality works. I’m happy for you. Secondly, you are inaccurate when you say that it’s a plugin on the Vera only. Maybe you should do your homework before you decide to critique my post. You can start by looking over the Android application here: https://play.google.com/store/apps/details?id=com.rtsservices.veraalerts
[quote=“integlikewhoa, post:3, topic:194208”]Yeah I don’t agree with the OP at all. I was using this app for few years without issues. I’m not sure if you went threw the troubleshooting steps, asked for help, or what you have done but this looks like a pointless rant more then anything else.
I see you have a few posts on this app and the 2nd to last one saying you love it. The last one seems to be a UI7 config problem. So I’m not seeing how it got to this post.[/quote]
This isn’t a pointless rant. It’s warning others to find another solution before wasting their time. As I mentioned, this setup makes my phone noticeably warm in my pocket and burns my battery out in a matter of hours. It uses more power than even the Android system itself, and possibly more than all other apps and functions on the phone, including the display. Maybe your ancient phone handles it better since you say that you’ve been using it for years, but apparently the latest versions of Android do not gel well with it.
Secondly, the LAN profile does not work as advertised (and I’m not the first to discover this – if you don’t believe me take a look through the posts from other users that I discovered while trying to figure out what’s wrong with it). Several of the functions mentioned do not work, even when following directions exactly. For example, I’m able to send an email to one recipient but when 2 addresses are entered separated by a comma, both fail.
The post where I said I “love it”, as you put it, is before I had experimented with it long enough to realize that this is an unfinished product with glaring faults. I don’t believe that there is anything wrong with my UI7 configuration.
If I seem overly upset, it’s because, admittedly, I’m pissed off and sick and tired of all of these technologies that are being sold that just do not work. This last few weeks I’ve spent countless hours researching and learning how to set things up, checking and double checking things and there is ALWAYS something that just doesn’t work as intended. Whether that is the developer/product designer willfully obscuring details in order to make more sales or not is always suspect. The end result is always the same – “it must be your configuration”. I could pull something out of the box, hook it up and whoops! My configuration is responsible for the ghost in the machine. Yeah. Right.
