Hi
I created two requests for Xiaomi devices
How to see all the requests of other people?
When I click on the links
https://jira.mios.com/projects/ECS/queues/issue/ECS-503
I only have this page
A search for “Xiaomi” does not yield any results
Hi
The integrations I mentioned earlier for Xiaomi that are on the first post of this same thread are the following:
Regarding this, if I understood correctly when you click https://jira.mios.com/projects/ECS/queues/issue/ECS-503, it actually takes you to https://jira.mios.com/servicedesk/customer/portal/72
Please confirm if that’s the case, and if so, please make sure you are logged in to your Ezlo Community account on the same browser you are using to open the link since those links are only visible for registered users that logged in through the same browser they are opening the links from.
As far as I know, the search option in https://jira.mios.com/servicedesk/customer/portal/72 does not really work for forum users, but if someone else from the forum can please confirm whether or not you can use the search option in that link that would be great.
Last time I tried to pair a Xiaomi Temp sensor it wasn’t detected or paired at all.
I’ll try it again tomorrow.
Please keep in mind those I posted a couple of posts above are integration requests, not integrations already done. ![]()
Hi
I confirm
Please let me know if you also checked that you are logged in to your Ezlo community account on the same browser from which you are opening the link so I can report the bug when attempting to access https://jira.mios.com/projects/ECS/queues/issue/ECS-503 and if you don’t mind testing whether https://jira.mios.com/projects/ECS/queues/issue/ECS-505 gives you the same result, that would be great.
Hi
I arrive on this page for each link after being connected
That’s quite odd. I think it is related to your mobile device. Could you please check if it also happens when accessing from a computer’s web browser while logged in to your community account? The part where I ask if you are logged in to your account is important, since it will not let you see it unless you are logged in.
Is there really no way to turn off notifications for every new Jira report, without having to disable them one at a time? It’s overwhelming!
Hello @Pitt13
I’ve checked with the team and it seems that you should be able to see all tickets created, can you please check once more and let us know.
Hi
Yes it’s ok
Thanks you ![]()
When clicking on Log in - MiOS, on computer browser, while logged in to community account, this takes me through to Service Desk. Using Firefox for both.
Hi Tony,
If you haven’t yet, please create an account at Service Desk so you can get access.
I am requesting that the developers add the following Z-Wave Plus water valve shut off device to the integration list:
https://www.econetshop.com
EcoNet Controls Inc.
12167 49th St. North, Suite 200
Clearwater, Florida U.S.A. 33762
Ph. 727-474-0929
Email: sales@EcoNetControls.com
I have been communication with EcoNet technical support and they said their EcoNet Bulldog devices do pair well with other Vera controllers. They indicated they were going to try to obtain a Ezlo hub to test with their Bulldog devices. Here is their contact information:
Blake Allen
Ph. 727-474-0929 or 905-330-7474
www.EcoNetShop.com www.EcoNetControls.com
Unique Home Automation Devices & Solutions
A Div. of ICI Controls Inc.
Again please add this excellent Z-Wave Plus water shut off device to your integration list.
Terry
The best way for you to reach the development and engineering teams for this kind of request is by using the following option toward the top of the Community forum:
Cheers!
HEIMAN HS1CG Z-Wave GAS Sensor
http://www.heimantech.com/product/?type=detail&id=34
Apparently this device does not work on Vera? As it uses command classes Vera doesn’t support they say.
Hello @cw-kid
That’s correct, that specific model is not integrated with the Vera controllers.
In case it is not listed in the devices of the first comment of this post, you can create an integration request of this device for the Ezlo controllers.
Integrations to have:
Reactor
Ecobee
Zooz and GE/Jasco devices (should be standard zwave compatible)
Anything that helps with geofencing and presence detection
Reactor is a 3rd party logic engine plugin for Vera firmware hubs.
It’s very unlikely there will be a new Reactor plugin for the Ezlo hub.
The developer has moved to a new system called Multi System Reactor (MSR). This currently supports Vera hubs, Hubitat and Home Assistant.
MSR runs on a separate device like a Raspberry Pi, NAS or Windows box.
MSR may at some point also support Ezlo hubs, hopefully fingers crossed, but it all depends on if the Ezlo APIs are up to the job?
Ezlo also plan to have their own native logic engine similar to Reactor, so if that’s decent enough and capable, we might all be using that instead.
I’ve added a New Device Integration request for this natural gas detector:
https://jira.mios.com/servicedesk/customer/portal/72/ECS-560
