Custom Intents to work with Tasker, Llama and NFC Tags:
For an always updated list see this link: http://www.authomation.net/documentation/intent-usage
On / Off Binary Switch & Dimmable Light - authomation://device/VeraID/deviceID/[on|off]
Example: To turn on binary light for device 8
authomation://device/3123456/8/on -
Dim Dimmable Light - authomation://device/VeraID/deviceID/dim/75
Example: To dim dimmable light for device 8 to 75%
authomation://device/3123456/8/dim/75 -
Lock / Unlock Locks - authomation://device/VeraID/deviceID/[lock|unlock]
Example: To unlock door for lock device 23
authomation://device/3123456/23/unlock -
Arm / Bypass Security Sensors - authomation://device/VeraID/deviceID/[arm|bypass]
Example: To set security sensor device 10 to bypass
authomation://device/3123456/10/bypass -
Toggle - authomation://device/VeraID/deviceID/toggle
Example: To toggle binary light device 8
authomation://device/3123456/8/toggle -
Thermostat set point - authomation://device/VeraID/deviceID/[setPointCool|setPointHeat]/77
Example: To set thermostat device 17 cool setpoint to 77
authomation://device/3123456/17/setPointCool/77 -
Thermostat fan mode - authomation://device/VeraID/deviceID/[ContinuousOn|Auto]
Exmaple: To set thermostat device 17 fan to Auto
authomation://device/3123456/17/fanmode/Auto -
Thermostat mode - authomation://device/VeraID/deviceID/[Off|CoolOn|HeatOn|AutoChangeOver]
Example: To set thermostat device 17 to heating mode
authomation://device/3123456/17/mode/HeatOn -
Scene - authomation://scene/VeraID/sceneID
Example: To run scene 33
authomation://scene/3123456/33 -
Alarm Panel - authomation://device/VeraID/deviceID/alarm/[arm | disarm]/pinCode
Example: To disarm alarm panel with device id of 31
authomation://device/3123456/31/alarm/disarm/1234 -
AV - authomation://device/VeraID/deviceID/av/[command]
Commands: [play | pause | stop | next | previous | rewind | fastforward | repeat | shuffle | vol | mute]
Example:
To set av with device id of 83 to play
authomation://device/3123456/83/av/playTo set av with device id of 83 to volume of 55 percent
authomation://device/3123456/83/av/vol/55To set av with device id of 83 to mute on or off
Mute On:
authomation://device/3123456/83/av/mute/1Mute Off: authomation://device/3123456/83/av/mute/0
Change VeraID to the id of your vera unit and deviceID to the ID of the device.
NFC Task Launcher App Instructions:
- Launch NFC Task Launcher
- Click the plus sign at the top right corner of the app.
- Select either “New Task” or “New Switch” (if you want to toggle between actions).
- Enter a tag name (can be anything you want to help identify the tag action).
- Press the “Add actions” button.
- Select “Applications & Shortcuts”
- Select “URL” and click next.
- Enter the authomation uri syntax. For a scene it would be authomation://scene/1234567/20
Where 1234567 is the vera unit id and 20 is the scene number to run. - Press OK when done entering the uri in the dialog box.
- Click on the “Save & Write” tag at the top right hand corner.
- In the options section, uncheck write tag name. (This will free up some data to be written to the tag)
- Place tag on the bottom of your phone and let the tag writer write to the tag.
- Once the tag is written, you should be good to go and the tag should function as it should.
- Garrett
