Hello Everybody.
I am using a Vera2 and a SQ Blaster remote, both controlled by the SQ Remote HD App. My target now is to send commands to the SQ Remote by running a scene on the Vera. The SQ Remote Plugin is installed and everything seems to work, if a scene is activated the the SQ Blaster blinks, but the TV shows no reaction.
Here is what I did in detail:
I Am using a Vera2 running on the Beta Firmware 1.1.1338. The following plugins are installed: dataMine, Ping Sensor, Generic IP Camera, Google Weather, Smart Phone Web Interface. The SQ Blaster is running on the Firmware A079.
I installed this plugin according to this procedure.
I created a device using the both files from the plugin D_SQBlaster1.xml and I_SQBlaster1.xml and called the device “SQ Blaster”. In the Advanced-Tab of this device I entered the IP of my SQ Blaster. This seems to work fine since the device is shown as “up” and all information’s about the SQ Blaster are shown.
According to this procedure I then created the two files D_SQdev1073736426.xml and I_SQdev1073736426.xml out of the SQ Blaster Backup from box.net. All three files are attached to this post.
I then created a new device to represent my TV using the two files created in step 4 and called in “Sony Bravia”. In the tab “Settings” of this device I added the SQ Blaster as it’s infrared transmitter.
Then I created a scene and in the tab “Advanced” added a step “Sony Bravia - Toggle OnOff”.
Now if I run the scene the SQ Blaster blinks, so something seems to be sent, but the TV shows no reaction at all. When I use the SQ Blaster App on the iPhone everything works just perfectly. So I thought the wrong Pronto Code might be send, but by using “http://192.168.x.xxx/cgi-bin/cmh/log.sh?Device=LuaUPnP” I found that the pronto code which is sent is exactly the one which is also in the file dev1073736426.xml and I_SQdev1073736426.xml, basically the correct one:
02 11/17/11 18:30:45.012 LOG_CHECK_MEMORY_LEAK pMem start 0xa2a000 now 0xa4a000 last 0xab0000 leaked 131072 <0x803>
02 11/17/11 18:31:00.824 UPnPCallbackEventHandler 0 start PIDLOG2 23279 <0x2c0c>
08 11/17/11 18:31:00.824 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunScene <0x2c0c>
08 11/17/11 18:31:00.825 JobHandler_LuaUPnP::HandleActionRequest argument SceneNum=15 <0x2c0c>
08 11/17/11 18:31:00.826 Scene::RunScene running 15 DREAM <0x2c0c>
08 11/17/11 18:31:00.826 JobHandler_LuaUPnP::HandleActionRequest device: 41 service: urn:micasaverde-com:serviceId:TogglePower1 action: OnOff <0x2c0c>
08 11/17/11 18:31:00.827 JobHandler_LuaUPnP::HandleActionRequest device: 36 service: urn:micasaverde-com:serviceId:IrTransmitter1 action: SendProntoCode <0x2c0c>
08 11/17/11 18:31:00.828 JobHandler_LuaUPnP::HandleActionRequest argument ProntoCode=P6501 802c 4a32 dbaa dc4d dd2c a526 3d20 427f 8cc4 0f67 d291 9f35 bff7 d926 dda7 137d eb0b ac1e eba4 fd0d 8a2b 872c e5aa 4772 7189 036c b892 7b93 8c96 7836 00af <0x2c0c>
50 11/17/11 18:31:00.860 luup_log:36: Web request returned status=200 response=
in 0ms <0x2c0c>
Now I don’t know what else to do. Did I miss a step in the installation procedure? Did anyone of you have similar problems? Can you help me analyse the log, although it seems right to me? Are the attached files correct or do I need to adjust them?
Any ideas are greatly appreciated, thanks so much for your help!
P.S: Thank you very very very much @guessed for creating the plugin and providing all these information’s to this community!
