This is dumber thant dirt.
I want to set up my GE45601 remote control. It can have 18 scenes, 18 “lights” and 18 groups. I have a 14 devices I’d like to control.
First off, I haven’t figured out how to control devices directly with the remote control. But you can set up one scene to turn on the device and another to turn it off, then assign the respective buttons to the “on” and “off” scenes. Tell me there is a better way.
I gleaned this information from other posts, but it needs to be put in many times so people can find it.
First, you have get your remote control to be seen by the Vera. This step will wipe out the information in your remote control. This so you can create events in scenes associated with the remote control.
In the web browser (I’m using UI4) click on “Add/Remove devices” Oh, you don’t see it? Well duh! Of course everyone knows it’s the little tiny “+!” icon near the top of the page.
Click on the [Next] button in the “z-wave” box.
Click on the [Add One] button in the “For battery operated …” box. Pretty cool graphics, eh? Ya think they could have spent some time on documentation? Naw, a waste of time, the pissed off users will write it for them.
Oops! Damn! Your remote control wasn’t ready yet. But, hey, you love to futz around. Click on the [Close] button in the “Success” box.
Get your remote control ready by pressing and holding the [SETUP] button. (why isn’t the button [SHIFT] with a secondary [setup]?). “LIGHT SETUP” will appear in the display.
These next three steps are only for the first time you link to the Vera
6) Six [–>] to get it to display “NETWORK”
7) press [OK] to get it to display “RESET”
8) Get the remote control within a meter of the Vera
use the [<–] button to get back to “TRANSFER”
Then pres [OK]
Now you have about 30 seconds to get back to the computer which should have a [RETRY] button on it (from step 4). Click [RETRY]
While the computer is displaying “SUCCESS”, the remote control is displaying “RECEIVING”. The remote control will, if you are lucky, display “SUCCESS”, too, but only very briefly.
Now go make up your scenes, test them out with the [RUN] button and see how cool things can be. OK, that was fun. Took you a freaking long time, didn’t it? But it’s still pretty cool, eh? Now you’re ready to link your scene to a key on your remote.
Click on the little icon [spanner] of your scene.
Click on the “EVENTS” tab.
From the drop down box, select your remote control. Frik! It doesn’t have a name, just a number. Well, you can name it later. Now that’s a totally intuitive task. Oh, all right, in your unamed device box, click [spanner], ADVANCED tab, in “name” box put in some note worthy name for your remote control, something link, “Remote Control”.
Then appears the “What type of event is the trigger?:” drop down box. You have two choices, “A scene is activated” or “A scene is de-activate” Well off course you knew immediately that these refered to the “on” and “off” (respectively) of the button you’re about to enter. You’re a genius!
“Name for this event” is anything you’d like it to be; how about “Remote control button pressed”?
Ah! “Which scene number” The clever marketing toad at MiCasaVerde thought it was so obvious. I mean, like, you’ve been working with scenes in the UI4 and it’s one of those. Well, no, here is where you’ll enter in the number of the button you’ll push to run your scene of the UI4. Our GE genius’s numbered the buttons 1-18, where 1-9 is the actual button and 10-18 is the 1-9 button (respectively) but the shift button needs to be pressed first to get to numbers 10-18
After the button number is entered, press tab or click somewhere, then click on [Back to events]
Close the window by clicking on the [X] in the upper right corner.
Not done yet! CLICK ON “SAVE”! Huh? WTF is that? Remember the frickin’ “Add/Remove” button? It’s on the same bar over on the right. You’ll remember to do it automatically, eventually.
Whew! All done.
Well you are if you only used buttons 1-9 and only chose “Activate” Ask your Green Little house frau’s why you’re not done yet.
For some f**king reason you have to go back and do steps 1,2 (wait, don’t do 3 yet) 5, 10, 11, 3, and 12.
So you got it? Set up a scene for turning things “on” and assign it to the upper half of a key with “activate” and the key number (add 9 if the key is shifted) Then set up a scene for turning things “off” and link it to "de-activate and the key number (add 9?).
