v1 does not yet exist. But yes, you can overwrite beta 1 files with beta 3 files.[/quote]
I’m thinking once v1 is released in the marketplace.[/quote]
When available in the marketplace, you will install it from there and that will overwrite the old files. A new device will probably be created. Just delete it to keep only trhe old one and that should be ok. I am not sure if the old device will be considered as attached to the installed plugin. If not, due to a UI5 bug, you will have a message telling you that the plugin will be uninstalled when you will delete the device. In fact, files are not removed.
I will check the real behavior before releasing it and will tell you the procedure to follow.
I installed beta 3 on UI5 and everything is running fine.
I am using a number of kaku devices (arc and also old ac), 3 orgeon scientific temp/hum censors and 2 huger temp sensors.
Just wanted to let you know you did a great job with this software.
This sounds really good noting I can’t find any Zwave/VeraLite pool/spa temperature sensors at the moment. Can I ask a few questions:
a) One would choose the RFXtrx433E USB 433.92MHz unit to purchase to match the frequency of a WT0122 (temperature sensor) correct?
b) I can’t see where to buy a RFXtrx433E USB 433.92MHz in Australia. Any issues do you think if I order from overseas (Europe) and use in Australia?
c) Is it OK to buy a USB extension board to put more than one USB device into the VeraLite? i.e. I’d be adding RFXtrx433E as well as my CurrentCost connection (for solar generation / power usage monitoring)
d) Wondering if the WT0122 signal from the backyard will make it to where my VeraLite currently is, which is kind of in a room on the front side of the house (brick house), so effectively a couple of rooms to pass through. Any options here besides having to relocate where my Veralite is?
Installed beta3 on UI6, still the same issues concerning manual device creation or autocreate button which is not working. Also no way you can edit a device and drop down menu are all empty.
Except that, all devices, I have 15 of them, are working fine.
