Dear all,
When I use the remote login page :https://vera-ui.strongcubedfitness.com/Veralogin.php of the ‘readme first’ section, I get a 404 not found error.
Has it been moved or is there an other problem?
Thank you.
Dear all,
Thank you.
For those interested: found out myself: https should be http.
Perhaps someone can change this in the ‘readme first’ section?
[quote=“backkri, post:2, topic:198093”]For those interested: found out myself: https should be http.
Perhaps someone can change this in the ‘readme first’ section?[/quote]
do not use http. ( not secure )
this remote access url has been decomissioned by the member who graciously offered to host it.
I created a new portal for remote access at : https://remotevera.000webhostapp.com/veralogin.php
I will modify readme post
http is not secure, I agree. So thank you for the new https version ![]()
This URL is reported as compromised/dangerous by F-secure browsing security. I have reported it to be safe to F-secure, so let’s hope it is ![]()
This URL is reported as compromised/dangerous by F-secure browsing security. I have reported it to be safe to F-secure, so let’s hope it is :)[/quote]
this is a virtual machine hosted by Hostinger group. it should be safe I hope.
https://fr.000webhost.com/
[quote=“amg0, post:6, topic:198093”]this is a virtual machine hosted by Hostinger group. it should be safe I hope.
https://fr.000webhost.com/[/quote]
It seems it is ![]()
F-secure replies:
[i]Thank you for your report.
Our analysis has found that the URL submitted is not harmful. Our security products have been updated to rate the URL as safe. The updated rating will take effect automatically via Security Cloud otherwise known as ORSP.
We apologize for any inconveniences this false positive may have caused. If there is anything else we can help you with, please feel free to contact us.
Best Regards,
Jia En
Malware Analyst
F-Secure Security Labs[/i]
Great if you can change the menu link to Remote Access login in AltUI menu to this new Url as well.
You can Check and eventually update the variable RemoteAccess of the altui device
Changed RemoteAcces variableand look like it is saved then go back to check an still the old address,
Same problem in each controler with latest firmware.
[quote=“michelhamelin, post:10, topic:198093”]Changed RemoteAcces variableand look like it is saved then go back to check an still the old address,
did you do a full browser refresh ?
what is the value of the RemoteAccess variable ?
Yes browser refresh and variable RemoteAcces is https://vera-ui.strongcubedfitness.com/Veralogin.php still dont save the new value: https://remotevera.000webhostapp.com/veralogin.php
[quote=“amg0, post:11, topic:198093”][quote=“michelhamelin, post:10, topic:198093”]Changed RemoteAcces variableand look like it is saved then go back to check an still the old address,
what is the value of the RemoteAccess variable ?[/quote]
Ok now it Work,
need to change the variable really in ALtui Browser not in Vera Ui.
I cannot access ALTUI anymore. Is there a plan for a new hosting account? Or has it already moved?
[quote=“markcm, post:14, topic:198093”]I cannot access ALTUI anymore. Is there a plan for a new hosting account? Or has it already moved?
Thanks[/quote]
What url do you use ?
[quote=“amg0, post:15, topic:198093”][quote=“markcm, post:14, topic:198093”]I cannot access ALTUI anymore. Is there a plan for a new hosting account? Or has it already moved?
Thanks[/quote]
What url do you use ?[/quote]
I am using https://remotevera.000webhostapp.com/veralogin.php
The page is loading today although over the past week or more I usually get an error message that the site is sleeping and it is a free development page. I’m guessing there is either a bandwidth limitation or a limit to how many different IP’s can log into it since it is a “free development host.”
[quote=“markcm, post:16, topic:198093”][quote=“amg0, post:15, topic:198093”][quote=“markcm, post:14, topic:198093”]I cannot access ALTUI anymore. Is there a plan for a new hosting account? Or has it already moved?
Thanks[/quote]
The page is loading today although over the past week or more I usually get an error message that the site is sleeping and it is a free development page. I’m guessing there is either a bandwidth limitation or a limit to how many different IP’s can log into it since it is a “free development host.”[/quote]
The site is down 1h per day.
Someone proposed another site I need to follow up with him
you can try to use https://hirwatech.com/veralogin/Veralogin.php
member @tedp has set this up for us
[quote=“amg0”]you can try to use https://hirwatech.com/veralogin/Veralogin.php
member @tedp has set this up for us[/quote]It should be up and running. I just had it redirect all http to https for security purposes.
Sent from my Nexus 5X using Tapatalk
[quote=“tedp, post:19, topic:198093”][quote=“amg0”]you can try to use https://hirwatech.com/veralogin/Veralogin.php
Sent from my Nexus 5X using Tapatalk[/quote]
thx, next version will change the remote access url to this one.
NOTE FOR ALL: remote access is only for ALTUI running on VERA. not on openluup
