*UPDATED: This Thread is an old Control Cube Thread created before the Control Cube Sub-forum came into existence.
This thread contains questions about Control Cube made by early adopters of the app. Feel free to continue the thread by asking more questions here or posting new threads in the sub-forum.
[quote=“hadiesper”]Check out Control cube. If you are looking for simplicity to set up and an advanced UI, its the right app out there. Plus the UI is awesome and integrates SONOS and XBMC directly from the App.
The current iOS version is 1.1. v1.2 has been submitted to apple and includes direct integration with Global Cache. It will also be so easy to set up (no creation of buttons or assignment of functions to UIButtons, just enter IP address, and an XML file with all the IR codes).[/quote]
Very nice graphics! Though, I would like to have the option to select which devices to show and in which room/section. Also, something I would wish for in any iOS app is to show a power meter gauge that displays what is consuming power for the moment (? la dataMine dashboard).
Currently once all your devices are added you can delete certain unneeded devices from the settings page under “Arrange Items”. Deleting them will remove them from the app database and not from the Vera. So it’s kind of like “hide”, but you cannot “unhide” unless you re-add the Vera. I’ll consider putting this feature into a next update.
Btw, there is a YouTube video on the control cube channel showing how to do this.
I like the idea of the power gauge,I’ll make sure to put that on our road map.
@waynehead99: you need to assign the scenes to rooms in your Vera. Or create a room called “Main” and assign all your scenes to it. Then on control cube “clear database” and re-add the Vera.
As for climate sensors, if you mean thermostats these are supported, also just assign it to a room. If you mean a temp sensor, I’ll make sure they are supported in the next update (within 1-2 weeks). Thanks for your patience.
I was able to get the scenes. I do like that the program seems to be pretty snappy, however, I am not a fan of the limitations on what can and can’t be displayed. I would like to have control over devices I may not want seen (like I have a couple “rooms” setup for admin things), I don’t want to see those rooms listed.
Having a main status page of quick things I do daily would be nice as well.
Overall, I like the feel and think it has potential, but it is limited for my needs in its current state.
@waynehead99: thanks for the feedback. You have valid points. My aim with the app was to keep it as easy to set up as possible but also maintain some form of scalability as an automation app as to being able to integrate more than just Vera. That’s why we have Sonos, xbmc, GC, and Knx coming soon.
Control Cube has an internal database that is completely independent of Vera. So you can simply delete a room or a device without any actual changes to Vera. Control cube simply won’t poll them from Vera anymore.
So if you want to get rid of a room, just delete it from
The settings tab->re-arrange items. If you still want to control devices in that room, I would suggest creating a room on the Vera. Call it “Main” and assign scenes there that control devices in other rooms which may or may not be hidden.
I hope this answers your concern, if not PM me and we can discuss it further.
@: bucko: the voice feature is not released yet (will be in about a month). We are currently working on 2 things: export/import configuration and an iphone app. This should be done in about 2 weeks.
As for the voice feature, for the start it will be English only and it will work for running scenes only.
// Sorry about my spelling I’m dyslexic and so you know all translations is translate by Google translate so don’t complain about my English spelling \
@Skaven: Thanks for your interest in Control Cube. Yes it is on our Roadmap to have Control Cube on Android. But this may not be until another 2-3 months.
We also plan to have cross-platform compatibility so that when you export a config from an iPad for example, you will be able to import it to any iphone or android without changing anything on the configuration.
I think you will have an outstanding product if/when you combine the flexibility from, for example, HomeWave with the graphics quality from, for example, Fibaro HC2. I think that a lot of us Vera users are looking for a good looking dashboard/control app but we are picky what comes to chosing the configuration and layout ourselves.
A question, is it possible to combine the weather report in the top of the screen with the temperature from an own local temp sensor?
@Freddan101: thank you very much I appreciate the positive feedback.
I do agree with you, I had to forgo some flexibility in the app in order to make it easy to set up.
Keep in mind I am a system integrator in my home country and I do have some projects (for example conference room automation or yacht projects) where control cube is not a good fit because in such cases you need to create your own interface and customize the buttons and the labels.
This brings me to the motivation behind control cube. As a system integrator, when we deploy a zwave/Sonos/IR control system at a villa for example. It takes us about 3 days to fully program the UI on other iPad apps. So we decided that we need to create an app that can be set up in about 30 minutes, and that’s exactly what control cube is about.
Take Sonos for example, in our old setup, we had to create buttons for play,pause, volume, playback, and at least 6 scenes for each zone that plays a playlist. Imagine doing this for a 14 zone deployment. That took up so much of our time! In control cube, you just add a Sonos device and specify it’s IP. It takes less than minute to set up a zone.
Back to your suggestions. I think we should create a virtual device in the app in the near future where you can assign a config file that can map buttons to Vera devices or scenes. That would make it flexible.
As soon as MCV approves a subforum for the app. I will create a dedicated thread for feature requests and let’s have all these in including your local temp sensor idea.
Btw, V1.2 of the app with GC control should be out on Monday. After that im working on 2 things (import/export database) and iphone app. After that we will dedicate time to feature requests. I need people like you who are power users and can really pinpoint their exact needs
I just want to add that control cube is not a hobby project I have on the side. It is actually funded by my company and there is an entire team working on updates to the app. So basically, we will continue to add features and updates throughout 2014 on a bi-weekly basis on average.
Sounds very promising, haidesper. I’m looking forward to test ControlCube and help out with feedback and ideas. I understand that simplicity is important for you. If you can combine that for the average user with more advanced options in the background you will be quite ahead of other iOS apps.
I hope that you only have to purchase the app once for both iPad and iPhone versions?
Thanks Freddan101. I am not so sure yet about making it a single purchase. But we will definitely make it fair for us and for customers. Ill tell you what though, if it does go on separate purchase, I’ll make sure to give you and other early supporters some free promo codes.
It is really slick and with that soft tone with few colors causing it to be easy to the eye and will look good wall mounted. Basically exactly what I have been looking for, for whatever iOS or Android pad flush mounted in the wall, and permanently on. The only GUI I have seen so far that has looked really slick is the Fibaro HC2 GUI, which is out of reach as long as I stay with Vera. And for me personally I have to point out that I really appreciate the simple light bulb icons etc. in CC. Keeping a low number of colors makes it easier to blend in with other interior.
When that has been said, there are some minor issues. I did not read this thread before buying, so that I was aware not all devices would work etc. But anyways, since you are here, hopefully there are possibilities of getting what I am missing in a future version.
Edit: Had problems moving a whole bunch of rooms around in different floors/sections, but found this video which solved my issues, was not aware it was possible to choose section/floor under rearrange and get all the rooms listed: - YouTube
After buying I noticed in the video that you mention Vera 2 or 3, but it seems it works with my Vera Lite? Any limitations?
I am missing humidity, temperature and lux/lumens sensors (Aeon labs 4-in-1 multisensor). The movement detection shows though.
I am missing power meter readings (NorthQ Power reader 9021).
Possibility of IP cam stream, ie. Foscam. What if the normal “control” part of the screen (not the upper banner) shows 1-4 camera streams when “idle”?
With the temperature sensors and and room organizing solved I think I will be running this as our “control center” for the house. The lumens/humidity sensors are not important as they are more for use in a scene/trigger, but I like being able to see the temperature for each room, and especially the garage, as it is important to keep it above freezing during the winter. I have also ordered a garage door sensor (angle sensor, ZG8101), not sure if I will need it displayed or if I will make a scene to show if the door is open or closed. The opener just needs an impulse so the feedback from the Fibaro device opening/closing is always off.
PS: I have bought almost all of the iPad/Android apps so far, AuthomationHD, HomeWave, Automator. I have been using Automator on my iPhone and AuthomationHD on a cheap Android pad.
I added the Vera and all rooms are created but I can’t open my Livingroom, it crashes Control Cube everytime.
My Danfoss thermostats show (null) because they do not report temperature, is it possible to display the Setpoint (I see the correct setpoint when I open a Thermostat in Cube).
Battery devices do not display battery status.
Would love to see more plugin (Netatmo, Hue…) support in upcoming versions
@ GR and nitehawk. Thank you both so much for the constructive feedback and the nice comments about our work. I truly appreciate it!
I am going to include answers to both your threads in this post in order to make things easier for other forum users looking for answers.
1. Edit: Had problems moving a whole bunch of rooms around in different floors/sections, but found this video which solved my issues, was not aware it was possible to choose section/floor under rearrange and get all the rooms listed: http://www.youtube.com/watch?v=tSjwzgF6uyU :)
Glad you figured it out from the YouTube video. And I must apologize because this feature is not really intuitive to do. We will work on making it a more graphical drag and drop feature rather than having to manually enter a section number you want to move the room to.
2. After buying I noticed in the video that you mention Vera 2 or 3, but it seems it works with my Vera Lite? Any limitations?
No Limitations on VERALite. I also updated this on our website, sorry for the confusion.
3. I am missing humidity, temperature and lux/lumens sensors (Aeon labs 4-in-1 multisensor). The movement detection shows though.
In the current version, we do not have support for humidty,temp,lux sensors,power meter. I will make sure we do that in an upcoming update though. Please note that right now we are working on v1.3 along with an iphone app. ETA is about 2 weeks, after that, Ill focus on supporting these devices.
5. Possibility of IP cam stream, ie. Foscam. What if the normal "control" part of the screen (not the upper banner) shows 1-4 camera streams when "idle"?
We do not plan to support FOSCAMs any time soon. Because you can view them on control cube using the WebView Device. Just go to settings->add device->web view. And specify the URL to be that of the FOSCAM. For example: http://192.168.2.27
You can also put a URL specific to the MJPEG stream. Use this link to find out your CAMS MJPEG Stream.
added the Vera and all rooms are created but I can't open my Livingroom, it crashes Control Cube everytime.
I happened to bump into this bug yesterday! The issue is most likely that you have too many devices or scenes assigned to your living room. For some reason there is a limit of 1 devices/scenes per room and if it exceeds that number, the app crashes. This bug was completely not intentional and we will be fixing it in the next update. Please try making adjustments to your vera and let me know if it worked.
I will have to buy a danfoss and test it out to know exactly what we can do to fix this. From what I see, we will most likely have to create a special plugin for this. If you like, we can temporarily put a “-” instead of “null” in the next app update. This way at least it doesnt look like something is majorly wrong!
Regarding battery status, we currently have no plans to put that into the app, but we will consider it in the medium-term.
Would love to see more plugin (Netatmo, Hue....) support in upcoming versions
The Cool Thing about Control Cube is that it is VERA independant. So technically, we can have a plugin for Hue or any other system with an API. It is the same concept we used for Sonos and XBMC integration. Btw, we plan to integrate NEST directly on our app as soon as NEST officially releases an API. I will check to see if there is an API for Netatmo or Hue, if it is easy and straightforward, I can do it in the next update.
Thanks again to GR and nitehawk. You feedback and participation in this thread in invaluable. Please keep your feedback coming and always know that your comments are actually being taken into account in our upcoming updates.
