Hello Rene ,
I copy pasted all that had HArmony Controll in the code, I hope it helps.
Thanks,
Cor
03 01/31/17 14:26:15.306 luup_log:58: Harmony Control: Harmony device #58 is initializing! <0x76e57520>
03 01/31/17 14:26:36.969 luup_log:58: Harmony Control: Harmony device #58 is initializing! <0x76be7520>
01 01/31/17 14:26:43.180 luup_log:58: Harmony Control: Connect, failed to open socket to hub 192.168.68.13 <0x745e7520>
01 01/31/17 14:26:43.181 LuaInterface::CallFunction_Timer-5 function Harmony_Setup failed [string "--[==[..."]:1689: attempt to get length of field 'devices' (a nil value) <0x745e7520>
09 01/31/17 14:34:57.645 JobHandler_LuaUPnP::Run device 58 Harmony Control room 2 type urn:schemas-rboer-com:device:Harmony58:1 cat 3:-1 id HAM58_CNTRL parent 0/0x116daa8 upnp: 0 plugin:8066 pnp:0 mac: ip:192.168.68.13 <0x77cb1320>
[code]50 01/31/17 14:35:08.101 luup_log:58: Harmony Control: Harmony device #58 is starting up! <0x74ce9520>
50 01/31/17 14:35:08.101 luup_log:58: Harmony Control: HTTPServer 0 <0x74ce9520>
50 01/31/17 14:35:08.102 luup_log:58: Harmony Control: Harmony_CreateChildren for device <0x74ce9520>
50 01/31/17 14:35:08.278 luup_log:58: Harmony Control: No child devices to create. <0x74ce9520>
50 01/31/17 14:35:08.278 luup_log:58: Harmony Control: GetConfig <0x74ce9520>
50 01/31/17 14:35:08.279 luup_log:58: Harmony Control: Sending command cmd=get_config <0x74ce9520>[/code]
01 01/31/17 14:35:11.280 luup_log:58: Harmony Control: Connect, failed to open socket to hub 192.168.68.13 <0x74ce9520>
50 01/31/17 14:35:11.280 luup_log:58: Harmony Control: CMD: errcode=423, errmsg=Failed to connect to Harmony Hub <0x74ce9520>
50 01/31/17 14:35:11.281 luup_log:58: Harmony Control: task: CMD: Failed sending command get_config to Harmony Hub - errorcode=423, errormessage=Failed to connect to Harmony Hub <0x74ce9520>
50 01/31/17 14:35:11.281 luup_log:58: Harmony Control: GetConfig, failed to send GetConfig command... errorcode=423, errormessage=Failed to connect to Harmony Hub <0x74ce9520>
01 01/31/17 14:35:11.282 LuaInterface::CallFunction_Timer-5 function Harmony_Setup failed [string "--[==[..."]:1689: attempt to get length of field 'devices' (a nil value) <0x74ce9520>
