Following the tip of Ap15e to open a new thread, i copied and paste our initial correspondence in a new thread here.
Im open to suggestions while im trying to contact Ycam development!
----------------------------------copy paste---------------------------------------
Re: DIY: Support for Foscam FI8908[w] (pan, tilt, patrol)
« Reply #56 on: Today at 12:42:54 pm »
Question @ Ap15e
Im using a Ycam Black (http://www.y-cam.com/) that is actually sold in the Netherlands as a package deal with Vera systems.
Although pan/tilt is not supported, zoom and streaming is…
Is there a way you could help me out with the Generic IP cam xml that im currently using (only got it to work with snapshot, even after reading the stream wiki http://wiki.micasaverde.com/index.php/IP_Cameras & http://wiki.micasaverde.com/index.php/Remote_Camera_Streaming).
---------------Ap15e’s reply-------------------------------------------------------------------------
You can find the relevant URLs on page 80 of the user manual (“7.7 Alternative methods of accessing the video stream”).
Neither the datasheet nor the manual seems to contain the information that is required to create a customized Luup plugin that would enable zooming.
You should ask the manufacturer for the programming manual, post it to the MCV forum and ask the community for help.
Options for my camera stream as per manual and the cams web interface:
RTSP MPEG4 stream: rtsp://192.xxx.xxx.xxx/live_mpeg4.sdp
RTSP MJPEG stream: rtsp://192.xxx.xxx.xxx/live_mjpeg.sdp
HTTP MPEG4 stream: http://192.xxx.xxx.xxx/stream.av
HTTP MJPEG stream: http://192.xxx.xxx.xxx/stream.jpg
HTTP ASF stream: http://192.xxx.xxx.xxx/stream.asf
HTTP snapshot image: http://192.xxx.xxx.xxx/snapshot.jpg
I got the snapshot to work, but not the stream (so far).
Also the cam supports 1x zoom from within the native NVR software provided from Ycam (Multilive) it would be aussumn to get that support working for the cam too.
Any takers?
Henk
