Plugin to support Ycam IP camera's
Henk, please replace your current cpanel_data.js with the one I attached and tell me if this fixes the password problem.
@mcvflorin
Ive tried the new Cpanel_data.js. Same results. As soon as i used a password with for instance an exlamation
i dont get a snapshot anymore.
Streaming still works!
Reverted back tot the bugfix 1481 version
Has anyone ever thought of writing an UPnP plugin for a camera?
My Y-cam supports UPnP AFAIK and im talking to the Y-cam UK company to maybe get their documentation on how to control that.
Suggestions?
Is there a step by step guide how to setup the Y-Cam (white) to work with mios ? The cams work and are accessable
via browser but I nave no idea how to get them to work with this system? How to fill the forms and set the parameters? Any advice?
I have a y-cam Knight S and cannot get streaming to work with my Vera2. Any ideas?
It seems like such a no brainer, but I have spent hours trying to get this working… and no go. I can’t image how hard it is to get working remotely…geez.
I’ve tried both camera plugins, multiple username/password combos(with & without special characters - even anonymous connections)
I can use a number of apps like the included Multiview app, Baby Monitor HD, IP Cam viewer etc… to view the video with no issues.
I’m using the following URLs from the manual for Vera2(this is also what is listed in IP Cam viewer)
Snapshots: /snapshot.jpg
Streaming: /stream.jpg
What am I missing?
Hi Henk,
I’m Emiel also from Holland, i’m using UI4 and Y-cam white.
I’ve tried all you said in the above, but my stream doesn’t show up in my interface.
Can you please send me some screenshots to show me the excact settings?
I must forget something but don’t know what…
Many thanks,
Emiel
Did anyone ever figure out a process for pairing Y-Cam with Vera? I have a Vera 3 and can’t seem to figure this out. I can access the stream via Chrome, BabyMonitor, etc., but I can’t seem to get it to work with Vera.
I’m using a y-cam knight with the vera 2.
Adding it is quite straightforward. I got it to work on both the UI4 and UI5. Take care: it is probably best to remove all camera’s if you’re upgrading from 4 to 5 and then reinstall the cam.
I used the manual option to add the device. You fill in the IP and the MAC addresses, the user name and password and the stream.
My experience: choose a username / pw without special -(&^*# characters. Just letters and numbers. Don’t use a password that should remain secure. It remains visible as plain text in the interface.
The stream: use “snapshot.jpg” to upload images to the archive. If I use this the device says ‘camera not responding’ but uploading to the archive is fine. If I use “stream.jpg” the preview shows more reliably and is continuously updated but nothing is stored on the server. I have 2 instances of the camera, 1 defined with stream and 1 with snapshot.jpg.
got the same with yawcam… 2 devices …
you can delete the first one with the snapshot capture.
the one with the videocapture , you put in advanced tab if you scroll down there is a variable container for snapshot, there you would add : /snapshot.jpg and press save
[quote=“Da_JoJo, post:29, topic:168288”]got the same with yawcam… 2 devices …
the one with the videocapture , you put in advanced tab if you scroll down there is a variable container for snapshot, there you would add : /snapshot.jpg and press save[/quote]
There is only the URL variable, I see no ‘snapshot’. Therefore I have one instance with URL = “/snapshot.jpg” and one with URL = “stream.jpg”. It would be nice if both parameters could be added to one instance.
donno maybe it should have another device file ?
device_type : urn:schemas-upnp-org:device:DigitalSecurityCamera:1
device_file : D_DigitalSecurityCamera1.xml
see attached pic for advanced details
Hi, I have had a couple of ycam knights for a while. Trying to add them to my veralite but I fail at the first step.
Choose manual
add the URL h t t p :// /snapshot.jpg
Enter simple user name and password hit next and I get the screen shot attached?
Anyone help, hope so as I think you all got past this stage.
Andrew
