[quote=âHansW, post:71, topic:184450â][quote=âreneboer, post:67, topic:184450â][quote=âHansW, post:66, topic:184450â]hello guys,
Maybe I am missing something obvious here but I would like to get me one of these Harmonys if I can program it to control the light and the blinds as well as my HT. For me that would be an important use case and I cannot find it in the features. Can someone enlighten me?
Thanks in advance![/quote]
Hi Hans, no that is not possible using this solution. For that you have to use one of the IR receivers discussed in other topics. The Harmony only reports the current activity over IP, but not any remote button clicks. You can basically do on your Vera what the Harmony app can.
Cheers Rene[/quote]
Thanks Rene,
I just bought one anyway and will check the forum for solutions to control lights and blinds through vera from it. Any good suggestions? I prefer a good solution over a cheap one and the least components the better. It feels silly that this hub is wifi connected as well as vera and we should need other components over softwareâŠ
And as a second question, is that because the hub just is not opened up enough for this, i.e.e its impossible without hacking it, or because the plugin has not implemented it (yet?
Hans[/quote]
The Harmony Ultimate Home can control devices in the SmartThings Controller. The only issue with Smart Things, IMHO, is that it uses Cloud Logic (all the logic is in the cloud, so if your internet is down, then no âautomationâ).
This is one of the many areas I think that MCV needs to catch up on. The partnerships that are being formed now will help define who has the better ecosystem (for lack of a better word).
edit: moved my response out of the quotes
